Old 05-15-2013, 02:43 AM
larchy larchy is offline
Vehicle: 2011 Dodge Ram
larchy is on a distinguished road
Default New to Dodge diesels-what motor do I have?
So I just got a 2011 Dodge Ram 2500 with the 6.7l cummins and I'm doing my due diligence to educate myself on this truck. My question comes from signing up for this forum. When filling out the info on my truck it asked what motor was in it and showed a split in 2011 with early motors having 650 ft/lbs of torque and late having 800ft/lbs. Is this accurate, and if so, how do I know which one I have?
Thanks.
Old 05-15-2013, 06:44 AM
Kcbigbadram's Avatar
Vehicle: 2014 1500
Trim Level: limited
Rep:503
If you have the 800 there should be a high output badge on tailgate, unless previous owner debadged the truck.
Other than that you would probably have to get your build sheet to know for sure
Old 05-15-2013, 12:42 PM
No badge, doubt original owner would have taken it off, all others are on. How do you get a build sheet?
Old 05-15-2013, 12:59 PM
Vehicle: 2014 1500
Trim Level: limited
Rep:503
http://www.ramtrucks.com/webselfserv...ucks/index.jsp
click on the send us an email, then give them your info and tell them your looking for your build sheet. they will get back to you normally in less than 24 hours
