Old 05-15-2013, 08:58 AM
madhatr02's Avatar
madhatr02 madhatr02 is offline
MOPAR or no Car
Vehicle: 2013 Dodge Ram
Trim Level: Longhorn
Color: Black / Gold
Rep:145
madhatr02 will become famous soon enoughmadhatr02 will become famous soon enough
Default Hardwiring my Radar Detector
Ok I have a radar detector that I pulled out of my F-250. In it I had the upfitter switches so I just hardwired it into those switches.
On my 2013 I am trying to find an easy wire to tap into so I can hook it back up. I have done tons of mods to my trucks and quite frankly, electrical more specifically wiring scares the crap out of me even though I have done it and understand the basic concepts. I am just tired of using the plug it just clutters up my truck.
These trucks have the super small fuses so I cannot find a fuse tap that will work so it will have to be a wire that is hot only when the truck is on.
Any ideas or something simple I am missing I would appreciate it.
Semper Fi,
Kevin
2013 Laramie Longhorn
aka "The Enterprise"
Old 05-15-2013, 09:20 AM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
I think I have seen some guys use the power coming from the rear view mirror. Not sure if it is switched power or what color it is.. Srry.. I do know if you have the crew or quad cab, the rear cig lighter in the console is only powered by the key, and the back of the console just pops off easily, but that would be a long way to fish some wire.. Maybe somebody else knows of an easier wire that's closer though.
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched -CST/Pro Comp 6" Lift - 35x12.50 ATZ P3 and 20x9 +1mm Fuel Mavericks -AMP Power Steps -8k HID -HEMIFEVER Tune
Old 05-15-2013, 08:52 PM
steveschaedel's Avatar
steveschaedel steveschaedel is offline
Vehicle: 2012 Power Wagon
Rep:61
steveschaedel will become famous soon enough
I did a write up on the hard wire into the rearview
http://www.ramforumz.com/showthread....radar+detector
2012 but the wiring should be the same if you have a uconnect rear view.
Old 05-16-2013, 08:48 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
You can tap into any of the power plugs in the center console that has a key symbol on them (already fused circuit). Your radar detector uses very little power so you don't need to wire it to the fuse panel. Just make sure you get the positive and negative wires correct.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 05-19-2013, 04:10 AM
madhatr02's Avatar
MOPAR or no Car
Color: Black / Gold
Rep:145
Thanks I will have to try this. I have an Escort detector as well with the hardwire kit.
Semper Fi,
Kevin
