Old 05-15-2013, 12:51 PM
lbram81's Avatar
lbram81 lbram81 is offline
Vehicle: 2013
Rep:99
lbram81 will become famous soon enough
Default Tailgate Straps Different Lengths???
Brought my truck home from dealer few days ago. Sitting outside checking it out, open the tailgate and notice there is much more tention on the passenger side strap than the drivers side strap. Dealer ordered new ones, went today to have them installed, same result. Tailgate perfect and all connections for straps at exact same measurements on each side. Even the tailgate straps are equal length! Tech said he is going to contact Chrysler and see if they are aware of this. Checked other trucks and they were just about the same. Anyone go and check this on their trucks?
I put a ATV in my bed and am now terrified the tailgate will fall off!
Advise please...........
Real question is: Does Ram Quality Control Personnel really exist???
Old 05-15-2013, 12:53 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
I have the same issue on my 2012. I'm not sure why they're like that.... As soon as I sit on the tailgate the tension evens out but it seems a little weird that they do that just sitting. My guess is that maybe the cable mounts on the bed or tailgate aren't in the exact same position side to side which causes there to be more tension in one than the other?
Old 05-15-2013, 01:17 PM
Bhbdvm's Avatar
Bhbdvm Bhbdvm is offline
Vehicle: 2015 Ecodiesel Crew Cab 4x4
Trim Level: Outdoorsman with 6.4
Color: Prairie Pearl
Rep:29
Bhbdvm is on a distinguished road
I have the same issue but it when I stand on the "slacker" side it tightens up. I also noticed this on my previous trauma. I don't think it will be a problem.
Old 05-15-2013, 02:50 PM
Asur Asur is offline
Vehicle: .
Rep:4373
No issues on my 2012, never noticed it was off before, checked now, no issues, wonder if its just over time they stretch to the same length? Steel cable, should not stretch.
Old 05-15-2013, 03:22 PM
TonyG-'s Avatar
TonyG- TonyG- is offline
Vehicle: 2010 Ram 1500
Rep:192
TonyG- has a spectacular aura aboutTonyG- has a spectacular aura about
Mine are the same... didnt put too much thought into it though
Old 05-15-2013, 06:50 PM
shaner82's Avatar
shaner82 shaner82 is offline
Vehicle: 2013 Dodge Ram Sport
Rep:47
shaner82 is on a distinguished road
Mine are the same on both sides. No slack in mine.
Old 05-16-2013, 11:31 AM
ILuvaMyTrucka's Avatar
ILuvaMyTrucka ILuvaMyTrucka is offline
Vehicle: 2014 Ram 1500 4x4 CC
Color: Maximum Steel Metallic
Rep:38
ILuvaMyTrucka is on a distinguished road
I have slack in my driver side as well.
My brother bought a 2013 ford F150 and he noticed it on his driver side and pointed it out to me. My other brother has a 2010 ford F150 and we checked his and it was the same way on the driver side.
Current: BakFlip FiberMax, Pillar Tape Removed, Partial Debadge (moved hemi badge to tailgate), Tinted Fronts to Match Rears (15%)
Future: TBD
Old 05-16-2013, 05:26 PM
lbram81's Avatar
Vehicle: 2013
Rep:99
Ok so many do have the same problem, some don't. Thats odd. If I sit on the tailgate there is tension on the "loose" strap.
So what do you guys think about driving an ATV up on the bed?
Old 05-16-2013, 05:31 PM
Rep:2036
Shouldn't be a problem at all. The cables will still be just as strong as required. As you said, once you sit on the tailgate that cable does tension up so it's not like it's out by much.
Old 05-16-2013, 05:48 PM
BigHornCAP BigHornCAP is offline
Vehicle: 2013 Ram 1500 CrewCab 8R70
Trim Level: BigHorn
Rep:18
BigHornCAP is on a distinguished road
Steel cables stretch more than you think.
long ones can act like an elastic band.
short ones will react to weather, moisture and other factors.
but i think it's more a function of the hinge on the tailgate, since it's designed to be easily removed it's not precision fit, so there is play, so it may not sit the same every time.
no need to worry about it falling out, the gate needs to be almost closed to get it out of the hinges (at least my other trucks worked that way)
