Dodge Ram Decals
Old 05-18-2013, 01:43 AM
j3andit j3andit is offline
Vehicle: 2013 Dodge Ram
Trim Level: Express 4x4
Rep:18
j3andit is on a distinguished road
Default will these work?
2013 express qc 4x4. leveled with bills at 2.1, no rear coil spacer. wanting to run 33x12.50x20 toyo mt with 20" moto metal 951
will these just swap right out with the stock wheels and be ok?
or do i have to have a certain offset or spacers?
i know i would with 35" tires, just dont know with 33s
thanks..
Old 05-18-2013, 02:03 AM
Moderator
Rep:2140
It's the width of the tires that makes you need the proper offset/backspacing. On a 20x9 wheel you need at least a 0 offset (5" backspacing). A -12 offset will work too, just stick out a bit further (0.5").
Here's a link to my thread installing 35x12.5 Toyo MT's on 20x9 -12 offset wheels. Yours would stick out just as far (if you go with a -12 offset), they just won't be as tall.
http://www.ramforumz.com/showthread.php?t=141365
Old 05-18-2013, 02:15 AM
Rep:18
ok thanks, so if i get this set up with the 33s and get the rims with 0 offset it will work? no rubbing at all?
Old 05-18-2013, 02:28 AM
Rep:18
also am curious in the xd rockstars 33x12.5x20 but see the lowest offset is +10
is there a way to make those work?
Old 05-18-2013, 01:44 PM
Moderator
Rep:2140
The 0 offset would be ideal, but yes the +10 should work as well. That gives you a similar back spacing to stock wheels with 1/4" spacers which lots of guys run 35x12.5's on. You might have a small amount of rubbing on the sway bar at full lock, but that should be it.
