Old 05-16-2013, 06:14 PM
MOFOGO's Avatar
MOFOGO MOFOGO is offline
Vehicle: 2012 Dodge Ram RCSB
Rep:33
MOFOGO is on a distinguished road
Default Front grille ram lit up!
I started this a couple weeks ago, but didn't get it finished until yesterday. Here are a few pictures, including the back-side. When the lights are off, the emblem appears stock. Like I said in my previous post in the exterior body mods section, this starts out as a hitch plug with red LED's. I only had to file (bevel) the top edge slightly to get it to fit. And by trimming just enough from the center of the grille (behind the emblem, about a one and one half inch square) for access to the bolt holes on the emblem, I can re-install my stock emblem, back as original. The lights are white LED strip lights. The only parts of the hitch plug that you use are the front (ram head), and the black rear section with the 4 threaded mounting holes. Having trouble getting pictures to come through, hope these work.
Old 05-16-2013, 06:19 PM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
You gotta show your work
It's a truck, not a cream puff
Old 05-16-2013, 06:22 PM
MOFOGO's Avatar
Rep:33
Someone send Geek Squad my way (read my last sentence.)
Old 05-16-2013, 06:48 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
Check out this thread. This is the best and easiest way to post pictures IMO.
http://www.ramforumz.com/showthread.php?t=139666
Old 05-16-2013, 07:06 PM
MOFOGO's Avatar
Rep:33
Old 05-16-2013, 07:15 PM
MOFOGO's Avatar
Rep:33
Default Pics
Old 05-16-2013, 07:19 PM
MOFOGO's Avatar
Rep:33
Feast or Famine! I don't even have to double-click to get double-posts! WTH?
Old 05-18-2013, 12:40 PM
Fidgetboy Fidgetboy is offline
Vehicle: 2011 Dodge Ram
Color: BLUE
Rep:22
Fidgetboy is on a distinguished road
I think that looks pretty cool!! Are you controlling it from a switch inside the cab?
Old 05-18-2013, 04:39 PM
MattHicks2010's Avatar
MattHicks2010 MattHicks2010 is offline
Vehicle: 2008 Dodge Ram
Trim Level: Big Horn SLT
MattHicks2010 is on a distinguished road
Very cool looking!
Old 05-18-2013, 06:06 PM
MOFOGO's Avatar
Rep:33
No, I found a hot (switched) wire in the headlight wiring. It will come on with the lights, and it stays on with parking, low-beam, high-beam, fog, or any combination. It looks exactly like the stock emblem when not lit up.
