Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 09-09-2013, 12:36 AM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
Since you live in Saskatchewan I will offer my experience.
If you have to travel gravel roads the airlift will NOT last. Sometimes it's the lines, but eventually the bags will have holes in them.
"I don't care to hear what your ideas are, mine are better"
Old 09-09-2013, 01:50 AM
For the ignition source I ran a relay off the TIPM. I built a bracket to mount behind the battery for 2 relays. One for the airlift compressor and one for other miscellaneous items. Then to turn the relays on I just found a keyed source under the dash and tapped into it since it would only be drawing minimal power.
I mounted the compressor on the subframe above the spare tire. I figured it was fairly protected from weather up there and made it very easy to run all the airlines and wiring.
This sounds like a pretty neat setup
