video installing hubcentric spacers - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-16-2013, 09:21 PM
dwanton's Avatar
dwanton dwanton is offline
Vehicle: 2015 Ram 1500 ECO Diesel
Trim Level: crew cab SLT
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:80
dwanton will become famous soon enough
Default video installing hubcentric spacers
i needed to get some space between the upper control arm and the new tires I bought .
tires are nitto mud grapplers 33x12.5x20's and a 1.5 front level kit .
I ordered a set of custom made hubcentric spacers cost was $90 plus shipping.
this is who makes them -- http://www.motorsport-tech.com/ I talked to Junior
3/8 is the smallest that they make due to the thickness of the lip on the factory rotor.
if your rotor has never been replaced or taken off you will have to remove the 2 aluminum washers with a pair of needle nose pliers.
I only did the front for now because I wanted to see what it looked like and if they were the thickness I needed.
after installing the spacers , I turned the wheels all the way in both directions and they don't hit the sway bar , upper control arms or anything else. But I am sure if I went off road they might hit .
click on the picture to play the video
2015 Ram 3.0 EcoDeisel crew cab -- LEER XQ cap -- Ram Bed Rug -- LED interior lights -- super white 7500k headlamp and fog lamp bulbs -- FoxBox with 2-10" Alpine type R -- Kenwood Amp -- Added factory Reverse Camera --
Old 05-17-2013, 06:34 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Great video! Thanks for posting
Old 05-17-2013, 07:31 AM
scmedic09's Avatar
scmedic09 scmedic09 is offline
Vehicle: 2010 dodge ram
Color: Brillant Black
Rep:168
scmedic09 has a spectacular aura aboutscmedic09 has a spectacular aura about
great vid! perfect for some people that arent sure what/how the spacers help out!
Old 05-17-2013, 08:01 AM
hemipowerv8 hemipowerv8 is offline
Vehicle: 2013 Ram Sport CC 4x4
Rep:74
hemipowerv8 will become famous soon enough
I have the same spacers going on my truck next week! Thanks for the video.
Did you run the 35x12.50s without the spacers long? Did it rub all the time or ONLY when hitting a bump or turning?
I am considering installing my Toyo 35x12.50 all terrains without the spacers and seeing a while...then adding them if it's an issue as these are 3/8" and to me that seems like a LOT of thread to take away from the lug nuts...some concern pushing the wheel that far out...
EDIT: Looking at actual tire specs yours are 13" wide and mine are 12.5" maybe I can run without it...I have an extra 1/4" of space over what you show stock due to tire not as wide...
Mods: Tint, Line-X spray in, PD emblems, Weathertech mats, Honeycomb grille, Mopar tow hooks, Magnaflow 18" and Y, Bilstein 5100s @ 2.1" & TGC rear spacer .75", Toyo All terrains 35x12.50x20, 5" black tips, BakFlip tonneau cover, 87mm tb
Next: Gorilla lifetime lug nuts, CAI, Diablo tune.
Old 05-17-2013, 08:17 PM
dwanton's Avatar
Rep:80
I really enjoy doing the how to videos -- I like being able to do stuff myself . and hope the video helps other guys out.
the big mud nobbies on the side wall is the only thing that touched . if they weren't there I think I would have not needed spacers .
I ran the 33x12.5 without spacers for almost 500 miles -- and I could not full turn because they would hit the sway bar and upper control arm, but Ive had lifted truck before and as soon as I thought I was close to hitting or just touched , I would stop right away . I don't really have any places that requires me to fully turn hard anyways. but now that the spacers are on I can fully lock the wheel both ways and no rubbing .
Junior at motosport tech said that you need a minimum of 5 full turns on the lug nut for it to work -- and with the spacers on I got more than that -- I am not going to sweat it at all -- just check them every so often .
and with only 3/8 spacer you really cant tell from front to back -- so I might not even order spacers for the rear .
Old 05-18-2013, 05:34 PM
MoparMadness08's Avatar
MoparMadness08 MoparMadness08 is offline
Vehicle: 2016 Dodge Ram 1500
Rep:63
MoparMadness08 will become famous soon enough
I have the hub centric spacers on my truck. They worked great. I had 305/55/20 Falken Rocky Mtn Ats tires installed last weekend. No rubbing at all. Your truck looks great with those tires and wheels on. Nice job.
Old 05-21-2013, 09:16 PM
dwanton's Avatar
Rep:80
I forgot I took a couple pics of the spacers before I put them on.
so far they work great -- full turn both ways with no rubbing .
Old 05-23-2013, 07:07 PM
Ziegler00's Avatar
Ziegler00 Ziegler00 is offline
Vehicle: 2012 Ram Express Quad Cab 2wd
Color: Deep Red
Rep:13
Ziegler00 is on a distinguished road
what about regular spacers, such as these? http://www.summitracing.com/parts/GOR-SP603/
I am putting these on tonight with my leveling kit and wanna make sure I dont do it the wrong way
2012 Ram 1500 Express Quad Cab 2wd
"The high cost of livin, aint nothin like the cost of livin high"
Old 05-23-2013, 07:58 PM
dwanton's Avatar
Rep:80
I cant believe summit sells those for $6.99 --
just make sure the factory lock washers are off -- or pull them off with needle nose plyers. slap the spacers on and put the wheels back on -- super easy .
Old 05-24-2013, 10:02 PM
Rambunkshuss's Avatar
Rambunkshuss Rambunkshuss is offline
Vehicle: 2014 Dodge Ram
Rep:113
Rambunkshuss will become famous soon enoughRambunkshuss will become famous soon enough
So what are you guys doing about the lost amount of wheel stud length when adding spacers...???
Life`s tough, its even tougher if you`re stupid
