Truck a little sluggish? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 05-17-2013, 10:09 AM
EWC88 EWC88 is offline
Vehicle: 2002 Dodge Ram 1500
Rep:25
EWC88 is on a distinguished road
Default Truck a little sluggish?
My truck is feeling a little sluggish for some reason. When I go to get up on it, it feels like she doesn't take off like it use to. Thinking about doing seafoam then oil change, recommend anything else? I've done seafoam before to the truck, is it bad to do it repeatedly? Should I put it through vacuum line and in gas tank? Any other recommendations I highly appreciate!
Old 05-17-2013, 10:22 AM
JimsRamTruck2012's Avatar
Vehicle: 2012 Ram Express
Trim Level: Express Package
Color: Mineral Gray Matalic
Rep:327
The seafoam is a good idea, but how long ago did you do the last one? As the old saying goes too much of a good thing is bad.
Have you tried something simple like cleaning the throttle body or cleaning the fuel injectors. Also, when was the last time you changed the spark plugs?
Sometimes it's the simple things we forget or overlook that make the differance in how our trucks or cars proform.
Old 05-17-2013, 10:27 AM
32seventeen 32seventeen is offline
Vehicle: 2009 Dodge Ram Laramie QC
Color: Brillant Black Pearl/ Sandstone
Rep:25
32seventeen is on a distinguished road
I would put a good code reader on it and see it the computer is picking anything up?
It could be a fuel filter too...?
Old 05-17-2013, 10:29 AM
Rep:25
I know it needs oil change for sure which I check the filter out while doing that. I did seafoam I would say atleast 6 months ago but I am thinking more towards a year to year and half.
I have not changed my plugs and want to do that this summer. And never clean TB. How hard is it to clean TB? I'm a noob when it comes to that.
Old 05-17-2013, 10:31 AM
Rep:25
Yea I have no lights light up or anything on dash, should I go to autozone and have them run it with their machine they bring out or something better than that?
Old 05-17-2013, 11:02 AM
Rep:25
I am not sure how good of a reader autozone will have? You need something better than a basic reader, especially if your CEL isn't on.
If it is running fine otherwise. My guess is that you have a fuel delivery issue. It could also be timing? Then again, there are a lot of possibilities?
Old 05-17-2013, 12:29 PM
Rep:25
You think seafoam again will be bad?
Old 05-17-2013, 01:00 PM
Rep:327
If you did the seafoam a year or more ago you could do it again, but not sure as to how much it would help.
Cleaning the throttle body is as easy as removing the air intake tube and unbolting the throttle body from the motor. I use a CRC throttle body cleaner and it works just fine.
Also, if you never changed the plugs on the truck then do so. Those plugs must be worn out for sure and need to be preplaced.
Based on your post about no lights on the dash then having anyone plug into the pcm would be a waste at this point.
Old 05-17-2013, 01:19 PM
Big Boi's Avatar
Big Boi Big Boi is offline
Vehicle: 09 Hemi 1500
Trim Level: BigHorn
Big Boi is on a distinguished road
When was the last time you changed your plugs?
Old 05-17-2013, 01:20 PM
Rep:25
Ok I'll do those minor things now then hopefully I can get some days off to tackle plugs. You recommend doing wires as well? Any brands that are good or suck to stay away from?
