Old 05-18-2013, 02:20 PM
The Crow 1994's Avatar
The Crow 1994 The Crow 1994 is offline
Vehicle: 2013 1500 Big Horn Crew 4x4
Trim Level: Hemi 5.7L w/8 Speed
Color: Copperhead Pearlcoat
Rep:56
The Crow 1994 will become famous soon enough
Originally Posted by dodgetank View Post
Hello! This is my first post here. I just bought a 2013 ram sport 8spd with the "3.55" rear end. After reading about a bunch of trucks getting shipped with 3.21's, I crawled underneath and sure enough, i've been screwed.
I was just wondering if the 3.21 rear end is weaker than the 3.55 or 3.92? Or maybe towing heavy with the 3.21 would put too much stress on the tranny?? From what you posted, it really seems like they shouldn't have downgraded the tow rating for this combo.
Before I attempt to get the stealership to give me what I paid for, I just want to make sure it's the best move. I like the 1400-1500 RPM on the highway, but I don't like the idea of over taxing my tranny or causing damage to a weak rear end.
Did you order your truck from the factory? Did you specifically pay $50 more for the 3.55 option, or were you told the standard was with the 3.55's?
Mod List: Line-X Platinum Spray-On Bedliner, BakFlip VP Tonneau Cover, TufTruck 1223-V HD Coil Springs, Bilstein 4600 Shocks, Air Lift 1000 Air Bags, Air Lift Wireless One Remote System with On-board Compressor, & Weathertech Digital Fit Floor Liners
Old 05-18-2013, 03:11 PM
mdragon9 mdragon9 is offline
Vehicle: 2013 Ram Laramie Longhorn
Trim Level: Laramie Longhorn
Rep:16
mdragon9 is on a distinguished road
I don't see why the 3.21 would be any weaker than the 3.55 or 3.92, but I don't know that for a fact. I don't see how it would stress the tranny out more than the 3.55 since the ratios actually favor the 8sp/3.21 combo over the 6sp/3.92 combo on the lower gears.
They may have downgraded the 8sp/3.21 combo because in the top gear (8th) it will be way down out of the power band around 1200 RPM or it might be just pure marketing. I'm guessing the rational is the same as for the 6sp/3.21 combo or 6sp/3.55 combo.
For towing you can just drop down to 7th and be at the same happy place as the 6sp/3.92 combo.
Unfortunately Chrysler isn't helping any of you make the decision and they are the ones that are setting the recommended tow ratings. If it were me I would be demanding some kinda satisfaction from the dealer. It's one thing to change how something is built as long as it is meeting the same design requirement but this change up doesn't do that.
Old 05-18-2013, 03:20 PM
RedWingFan's Avatar
RedWingFan RedWingFan is offline
Vehicle: 2013 Sport Hemi RamBox ordered
Trim Level: 2013 Sport
Color: Dark Cherry
RedWingFan is on a distinguished road
Tested the spreadsheet mdragon9 posted. Right on the money for my 8 sp. 3.92.
Old 05-18-2013, 03:23 PM
Rep:2657
How can you compare apples to oranges ?
forgetting about the engine, V-6 or HEMI
just stick with the 8 speed transmission
with the 3 different differential ratios
3.21 has the lowest torque, but gets the best MPG, at any given speed the RPM will be the lowest of the 3
3.55 has mid range torque, MPG is not quite as good
3.92 has the most torque, but you lose a bit more MPG
torque is needed for pulling power & quicker take offs
Old 05-18-2013, 03:33 PM
dodgetank dodgetank is offline
Vehicle: 2013 Ddoge Ram
dodgetank is on a distinguished road
No, the truck was already built. The build sheet and window sticker said 3.55.
Old 05-18-2013, 05:20 PM
Rep:56
Did your window sticker show a $50 fee (US) for the 3.55?
That's not good. I should be picking up my Big Horn this next week and I ordered and paid more for the 3.55. My order sheet, build sheet, window sticker, and VOTS all showed 3.55. I will not be a happy camper if my truck does not come with what I ordered on it.
Old 05-18-2013, 08:15 PM
Breathing Borla's Avatar
Breathing Borla Breathing Borla is offline
Vehicle: 2013 Ram 1500 Sport 4x4
Color: Maximum Steel
Rep:89
Breathing Borla will become famous soon enough
mmmmmmmmm.....most torque
2013 Ram Sport Crew 4x4, 5.7, 8-speed, 3.92, LSD, Borla
2010 LTD Tundra DC, 4x4 RW Wheels 33" Cooper Maxx
2001 tundra, 2000 tundra
1995.5 Tacoma, 1997 Tacoma, 1998 Tacoma
Old 05-18-2013, 11:43 PM
I am not 100% sure what the window sticker said. It was on when the truck showed up but was removed when I picked it up. The build sheet said 3.55
Definitely have a look underneath before agreeing to take the truck.
Old 05-19-2013, 12:01 AM
Rep:56
Without a doubt! That's one of the first things I'm going to do. My salesperson is going to think I'm nuts when I crawl underneath the truck before I even set foot inside.
Old 08-11-2013, 03:44 PM
mdavis501 mdavis501 is offline
Vehicle: 2013 Dodge Longhorn
Trim Level: Longhorn
Color: Western Brown
mdavis501 is on a distinguished road
I found the drive ratio chart posted by mdragon9 to be very useful; however, I do not agree with the comment that "A hemi with the 8 speed and 3.21 should feel snappier overall than a hemi with the 6 speed and 3.55." The example given, and shown to be accurate from the chart, "at 1500 RPM, you should be going about 68 MPH with the 8 speed/3.21 and about 61 MPH with the 6 speed/3.55 combo." This is true, however, that is at 8th gear / 6th gear.
I guess it all depends on what "feel snappier" means, but I would evaluate that as how does it feel going thru the gears. The chart shows that at 1500 rpm the 3.21 ratio 8 speed would have you going at 9.74 mph at end of 1st gear compared to 13.82 mph for the 6 speed 3.55 truck (also at end of first gear). To me, that would feel "snappier" as I would be going faster thru first gear with the 3.55 truck than the 3.21 truck (regardless of the 8 vs 6 speed).
Do you read the chart that way, too?
