Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > VARARAM - Dodge Ram Performance!
VARARAM - Dodge Ram Performance! Vararam Industries was created to bring true racing technology to the street, the most efficient air induction systems on earth. Our air induction systems produce more Power and Torque, offering you more real world performance than any of the other intake system out there, We've been tested to be the best, compared to the rest and each time VR comes out on top. - Dodge Ram Performance!
Old 05-18-2013, 02:15 PM
mgbighorn mgbighorn is offline
Vehicle: 2012 Ram 1500
Color: True Blue
Rep:50
mgbighorn will become famous soon enough
Default another fourth gen issue
My truck is a 2012 ram 4x4 express. The intake is hitting the ac lines as well as one of the screw inserts? (dont know what to call them) dosent line up with the holes on the intake.
Hitting the ac lines
Dosent go all the way back
EDIT:
After looking at the pictures it looks like it is because the one hole dosent like up with the main body of the intake which may be the issue?
How much room should there be between the ac lines and the scoop?
This hole looks like it is in the right location
This hole looks like it is in to far by an 1/8 inch
What do i do now?
Old 05-18-2013, 03:10 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Okay first off it looks like you need to put it all together first... I have the exact same setup as you with 0 issues. It is a tight fit but it fits.
You need to lift it up and get the lower air dam down below the cross member first.
Then you need to drop the intake onto the TB and don't be afraid to push on the plastic air dam a bit. It's plastic, it will bend.
Chrome... in moderation.
Old 05-19-2013, 03:33 AM
redlightmike redlightmike is offline
Vehicle: 2012 Ram Express RCSB
Rep:36
redlightmike is on a distinguished road
Talking
To the OP, i had the exact same problem on the ac lines.. i ended up cutting a notch out of the lower air dam to fit around the line and then mounting it on the front of the upper piece instead of behind it.. seemed to work well. Everything is straight and level now
2012 Express RCSB..2/4 belltech drop, 22s,tonneau cover, 4.10s, true duals with x and magnaflows,vararam air grabber,180 tstat, 2800 circle d, diablosport trinity....headers and ported tb(coming soon)
Old 05-19-2013, 08:54 AM
MOTH3R MOTH3R is offline
Color: Maximum Steel Metallic
Rep:19
MOTH3R is on a distinguished road
No, you do not. They changed the design where the AC lines go into the condenser, which is causing the clearance issue. 2009's do not have that issue.
OP, you may need to contact Vararam for the new revised scoop they just started producing for the 2013's. I think the same changes may apply to your 2012. I would definitely ask them before I started cutting notches in anything.
Old 05-19-2013, 01:16 PM
Color: True Blue
Rep:50
well i cut a notch, to get it to work for now. I didn't want to take the intake off again and put the stock one back on.
I will be contacting Varraram monday to talk to them on the issue and get the revised scoop
Old 05-24-2013, 11:47 AM
32seventeen 32seventeen is offline
Vehicle: 2009 Dodge Ram Laramie QC
Color: Brillant Black Pearl
Rep:25
32seventeen is on a distinguished road
Hey Arth, my instructions said to move that wiring harness to the front. You look like your are blocking a lot of air flow with that harness in the way. Just an FYI.
