Old 05-19-2013, 01:21 AM
fxnytro17 fxnytro17 is offline
Vehicle: 2013 1500 Quad Cab
fxnytro17 is on a distinguished road
Default HID's Installed, What a difference!
Took my projectors out today and slapped in some plug and play high and low beams 6000k HIDs. Reason for doing so was because stock bulbs wasn't doing a good job sense this summer I will be driving 2100kms home and about 50% of that is going to be dirt road with little to no traffic and I need good lighting so I can feel safer and drive faster lol.
Anyways after doing this I realized that I should've done the fog lights as well just for appearance, either way looks great.
But just a question, do I hae to worry about these lamps getting to hot or anything where while using high beam im using the two bulbs the same time. Thanks
Old 05-19-2013, 01:34 AM
Before/After pics, Loves it
Old 05-19-2013, 01:51 AM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default Part #'s and such
Perhaps if you post up the brand, kit, items #s etc, more about the install the info about the heat, voltage and temperature can be evaluated.
Old 05-19-2013, 02:24 AM
All I can tell you about it is that its the 9006 types and 6000k intensity.
Old 05-21-2013, 07:28 PM
Dsabs Dsabs is offline
Vehicle: 2013 Dodge Ram
Dsabs is on a distinguished road
Typically Hid lights run cooler than traditional Halogen bulbs. The amperage is usually lower as well but it does depend on what brand/setup you go with. I would always recommend digital balasts.
