Old 05-19-2013, 12:11 PM
Allstate48 Allstate48 is offline
Vehicle: 2010 Dodge Ram-1976 D200
Trim Level: SLT- Orange&rust
Color: Cool Vanilla
Rep:53
Allstate48 will become famous soon enough
Default Transmission Maint.
We have a 010 1500 Ram with 47,000 miles on it Everything is good, I think, but when should I service the tranny? And what needs done? Just change the filter, and fluids, or something about flushing it. Thanks Doug
Old 05-19-2013, 01:27 PM
Arth's Avatar
Arth Arth is online now
Color: Mineral Gray Metallic
Rep:2028
According to the owners manual it says to change the fluid and filter at 60k depending on what your truck is used for. I follow the schedule and dropped my tranny pan and replaced the two filters at roughly 55K miles.
That doesn't get all of the fluid but it got a fair amount. My truck like yours was running just fine. I just chose to do it for peace of mind since I have 0 power train warranty and I have the means to do it myself.
Most will tell you it isn't required that early. If you pull your transmission stick and it is nice and pink you are probably okay. I personally just wanted to get it done.\
Currently at 67k miles- 0 issues.
Chrome... in moderation.
Old 05-19-2013, 02:03 PM
bighemi04's Avatar
Rep:623
A wise man once told me to never service the trans if you arent having any problems. I disregarded his advice with my last truck and 2 days after i had the trans serviced my solenoid pack went out.
Old 05-19-2013, 04:10 PM
Flight-ER-Doc Flight-ER-Doc is offline
Vehicle: 2010 Ram 1500 Crew
Color: Inferno Red
Flight-ER-Doc is on a distinguished road
On a related note, what transmission fluid to use? I've been using Mobil-1 synthetic in my GM and Ford products but I can't seem to find a synthetic that is MOPAR approved....
Old 05-19-2013, 04:41 PM
Rep:2657
the book calls for ATF 4
it is backwards compatible, meaning if your owners manual reads ATF 3
the ATF 4 is compatible
Chrysler's thinking
Type 9602/ATF+4 fluids was that it would have the same frictional characteristics as ATF+3. The paper explicitly states that this was because new clutch materials would not be introduced for this fluid and it had to be backwards compatible with ATF+3. Graphs in the paper show that the friction coefficient of fresh ATF+3 and ATF+4 is essentially identical, but as the fluid ages ATF+4 retains the “as new” coefficient while ATF+3 degrades.
The paper noted that one alternative was to use synthetic Group IV base stock, which are even more expensive than the ATF+4 solution, which provided Group IV style performance from Group III stock. ATF+4 meets strict low-temperature, oxidation, and volatility performance requirements and relatively low cost
Manufacturers can make ATF+4 fluids, but to use the trademarked ATF+4 name in their compatibility list, they must have their fluids tested and licensed by Chrysler engineers, and must use Lubrizol in their formulations. Licensed fluids are periodically sampled from stores to assure quality
http://www.allpar.com/mopar/transmissions/fluids.html
Old 05-19-2013, 11:37 PM
bighemi04's Avatar
Rep:623
Amsoil is Chrysler approved. Just order it through the link in my signature. You will be looking for the Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid
Old 05-24-2013, 09:08 PM
Rambunkshuss's Avatar
Rambunkshuss Rambunkshuss is offline
Vehicle: 2014 Dodge Ram
Rep:87
Rambunkshuss will become famous soon enough
And what does your operators manual tell you to do (???)
If you plan on doing it yourself..... only use ATF-4
Pay VERY close attention when doing the filters.!
Life`s tough, its even tougher if you`re stupid
Old 05-28-2013, 07:56 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
I think you may be mistaken. The list of "approved" (licensed) ATF+4® fluids is at this link:
http://www.centerforqa.com/licensedatf4brands.html
and Amsoil does not appear on the list. Amsoil fluid is not ATF+4®.
Old 05-28-2013, 11:30 AM
bighemi04's Avatar
Rep:623
I am actually not mistaken. Here is a list of all approved applications for that particular Amsoil ATF.
Applications
AMSOIL Signature Series Multi-Vehicle Synthetic ATF
is recommended for transmissions, hydraulics, power steering systems and other applications that require any of the following specifications:
Ford MERCON®, MERCON® V, ESP-M2C166-H; GM DEXRON® III; Chrysler ATF+4®, MOPAR® AS68RC; Allison C-4, TES-389; Audi G 052 162, G 052 990, G 055 025; BMW 7045E, LA 2634, LT 71141; Honda ATF-Z1 (not CVT); Hyundai SP-II and SP-III; Idemitsu K17; JWS 3309, 3314, 3317; Kia SP-II and SP-III, ATF Red-1; MAN 339F, 339 V1, 339 V2, 339 Z1, Z2 & Z3; Mazda ATF-M III, ATF-MV; Mercedes Benz 236.1, 236.2, 236.3, 236.5, 236.6, 236.7, 236.9, 236.10, 236.11, 236.81; Mitsubishi SP-II and SP-III; Nissan Matic-D, Matic-J, Matic-K; Shell 3403, LA 2634; Subaru ATF, ATF-HP; Suzuki 3314 & 3317; Texaco ETL-7045E, ETL- 8072B, N402; Toyota Type T-III and T-IV; Voith 55.6335.XX (G607), 55.6336.XX (G1363); Volvo 97340, 97341; Volkswagen G 052 162, G 052 990, G 055 025; ZF TE-ML 03D, 04D, 05L, 09, 11B, 14A, 14B, 14C, 16L, 17C.
Note: Not for use with CVT or Ford Type F applications.
Old 05-28-2013, 11:35 AM
bighemi04's Avatar
Rep:623
Proven in 100,000-mile, Severe-Service Taxi Fleet Field Trial
To demonstrate its effectiveness in severe service, Signature Series Multi-Vehicle Synthetic ATF was installed in vehicles owned by a Las Vegas cab company. The vehicles routinely encountered demanding stop-and-go driving loaded with passengers and cargo, while the desert environment presented extremely hot ambient temperatures, placing enormous strain on the fluid. Following 100,000 miles, a transmission was selected for analysis. The Aluminum Beaker Oxidation Test (ABOT) is one industry-accepted method used to determine a transmission fluid's oxidation resistance, which is a good indicator of its service life. Testing by an independent, third-party lab reveals that after 100,000 miles in severe service, Signature Series Multi-Vehicle Synthetic ATF resisted oxidation longer than required for new fluid to meet the Chrysler ATF+4 specification (see graph). Internal components, including the valve body and clutch plates (pictured), were virtually free of damaging sludge, deposits and wear, confirming the lubricant’s high level of protection for severe-service applications.
