Old 05-28-2013, 11:37 AM
bighemi04's Avatar
Rep:623
Outstanding Wear Protection
Varying speeds and loads causes torque multiplication and extreme stress on gears and bearings. AMSOIL formulated Signature Series Synthetic ATF with high film strength and premium anti-wear/extreme-pressure additives to help prevent wear during severe service. In the industry-standard FZG Gear Wear Test, Signature Series Multi-Vehicle Synthetic ATF that had been used for 100,000 severe-service miles achieved a “Pass” at stage 12 – the highest stage. The results exceeded the Ford MERCON V and Chrysler ATF+4 specifications for new fluid, demonstrating the lubricant's long-lasting wear protection
bighemi04's Avatar
Rep:623
Need anymore info?????
Old 05-28-2013, 12:47 PM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
So the Amsoil fluid is approved by Amsoil. But it is not approved (as meeting the ATF+4 spec) by Chrysler.
Old 05-28-2013, 01:32 PM
browndawg's Avatar
browndawg browndawg is offline
Vehicle: 2012 ram 1500 4x4 express rcsb
Color: true blue pearl
Rep:101
browndawg will become famous soon enoughbrowndawg will become famous soon enough
oh no here we go again
Old 05-28-2013, 01:44 PM
Hermes1 Hermes1 is offline
Vehicle: 2015 Big Horn 3500 Cummins TD
Rep:2559
Originally Posted by Rambunkshuss View Post
Pay VERY close attention when doing the filters.!
When you say "pay very close attention when doing the filters", what should one be looking for and or paying close attention to? Is there something unique or special? Just curious, I am quite a long way from having to do this, but would consider doing my own fluid change. Now you have me having second thoughts.
Old 05-28-2013, 01:49 PM
Vehicle: N/A
Rep:358
Changing the fluid and filters should not cause a trans to get screwed up, UNLESS one of the filters (usually, the main sump filter) is installed incorrectly. The main sump filter has a snout that plugs into a bore in the pump housing. There is a seal at this connection (which is pressed into the pump bore). If the old seal is OK (no cuts or nicks, and won't easily pop out) then leave it in and re-use it. If you replace the seal, the new seal MUST be installed into the pump bore, and tapped in flush against the casting all the way around (not cocked). Do NOT put the seal on the filter snout!! The other filter (the spin-on one) goes on like a conventional engine oil filter. Spin it in until the gasket contacts the case face, then turn it another 1/2 turn or so BY HAND until it's snug. Do NOT overtorque it, since the threaded snout on this filter is plastic and will crack if you crank it down too tight. The torque spec is 7 ft-lbs.
Old 05-28-2013, 06:36 PM
Rep:2559
Cool thanks, that splains it.
