98 Ram Hemi swap build - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-19-2013, 07:28 PM
98hemi-ram's Avatar
98hemi-ram 98hemi-ram is offline
Vehicle: 98 Dodge Ram
Rep:112
98hemi-ram will become famous soon enough98hemi-ram will become famous soon enough
Default 98 Ram Hemi swap build
Well figured I'd start a build thread here to show off my build.
I started out with a 98 ram 1500 RCSB 2wd with a 5.9L magnum. I bought the truck 5 years ago and have been slowly doing things to make it my own ever since. This is by far the biggest project I've ever done to this truck so far.
Heres a break down of what I have done/will be doing during this swap.
- 07 5.7L Hemi and 545rfe to replace the magnum
- Custom built wiring harness by hotwireauto.com
- Comp 260 cam
- 87mm ported TB
- CAI
- Electric fan conversion
- Dual gauge pod with AEM wideband a/fr and tranny temp gauges
- A/C delete (Never worked since i bought the truck anyways
- EGR block off kit
- 01 Dakota gauge cluster swap
I'm sure theres more that I'm forgetting but that should cover most of it.
And heres a few pictures from before and during the swap
98 Ram 1500 rcsb 2wd - 5.7 Hemi swapped with many upgrades
All mods listed in my profile
Old 05-19-2013, 07:42 PM
98hemi-ram's Avatar
Rep:112
And a few more of the hemi installed along with my custom gas pedal mount and e-fan setup.
Old 05-19-2013, 07:51 PM
98hemi-ram's Avatar
Rep:112
This weekend I've started putting all the wiring harnesses back in and started trying to figure out where all my other hoses and lines need to go again.
And here's a picture of the new custom engine wiring harness I never got a picture of the fuse box harness before it went back in.
Old 05-19-2013, 08:19 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Sweet build, very nice, truck looks great, nice stuff, thanks for sharing the pics. Reps for what your doing.
Old 05-20-2013, 12:30 AM
98hemi-ram's Avatar
Rep:112
Thanks man, its definetly been a fun project so far.
Old 05-27-2013, 09:47 PM
Vehicle: N/A
Rep:1045
wow how did I miss this one?!
so how's everything going with it now? any update?
Old 05-27-2013, 11:17 PM
98hemi-ram's Avatar
Rep:112
Everything has been going pretty good so far I've got all the wiring harnesses put back in and hooked back up. Only needed to change 1 sensor since they were different connectors but other than that it all plugged right in.
I think I've got all my vacuum lines hooked back up. Need to order some tranny cooler lines (was going to try and make my own but figured this way would be a lot easier).
Only other major things I need to get figured out still are a custom power steering line, and need to change the quick connect end for the fuel rail on the Hemi. (Hemi connector is larger than my old 5.9's)
Work has picked up again so it hasn't left me much time to work on it so progress has been slow the last few weeks.
Old 05-27-2013, 11:19 PM
98hemi-ram's Avatar
Rep:112
Oh will also still need to get my exhaust reconnected to the new manifolds and need to take my driveshaft into the local shop so they can change the slip yokes for me.
Old 05-28-2013, 01:28 PM
Vehicle: N/A
Rep:1045
this is some seriously cool stuff man. i am jealous for sure!
Old 05-28-2013, 11:52 PM
98hemi-ram's Avatar
Rep:112
Thanks man I'm at the point now where ill be happy to here it fire up for the first time lol
