04 5.7 ETC recall yet? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Recalls and TSB's.
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 05-20-2013, 08:42 AM
kittpowell1's Avatar
kittpowell1 kittpowell1 is offline
Vehicle: 2004 ram 1500
Color: red
Rep:17
kittpowell1 is on a distinguished road
Default 04 5.7 ETC recall yet?
the only reason i was scarred to get a hemi is happening now i have a 04 my etc started acting up this weekend after do a diy ram air intake with my k&n cai i have disconnected my battery it will reset for a few miles then come back on with rough idle im afraid to take my truck into dealership and have them see my mods and laugh so i want to get all my ducks in a row before causing hell at dealership also i recently put a superchips in my truck will it leave a trace on my computer if i unistall it before taking it in?
Old 05-21-2013, 10:42 AM
Raminator5280's Avatar
Raminator5280 Raminator5280 is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT Bighorn
Rep:56
Raminator5280 will become famous soon enough
Did you try clean your tb yet? And as long as you turn it back to stock tune it won't matter. Besides I'm assuming you do not have a warranty anymore since its 2004 so it shouldn't matter to them what you've done to your truck
DiabloSport Trinity w/CMR tune, K&N FIPK, 87mm ported TB, Dynatech LT Headers, Magnaflow cats, ypipe, & muffler, Jetstream scoop, diy ram air, push start
Old 05-23-2013, 12:27 PM
SI Integra SI Integra is offline
Vehicle: 03 Ram
Trim Level: SLT Sport
SI Integra is on a distinguished road
2nd cleaning the throttle body.
Old 05-29-2013, 06:49 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
I second (or third, whatever) what has been said. Clean your throttle body well and check everything you can see while you are doing it. It's very odd that it only started when you fabbed up your intake. Not saying you did anything wrong but if your issues started immediately after......have you considered returning it to stock to see what happens? At least go back and double check all your work.
I assume by ETC you are referring to the electronic throttle control? So you are getting the little lightning bolt symbol lit up in the cluster? I really don't think this is an extremely common problem. I have read about a handful of people seeing the lightning bolt but nowhere near enough for it to be considered a recurring issue with these trucks. Regardless, Chrysler isn't going to do a recall on a 9 year old vehicle anyway so I wouldn't get my hopes up about that.
Let us know how the TB cleaning and recheck of everything goes.
Old 08-14-2013, 02:08 AM
Color: red
Rep:17
I cleaned my TB really good checked all my work and since i have removed my mods and it will still kick on and off at random enough so i know that all i have to do is turn my truck off reatart and it clears its self and we are good to go. When it kicks on it runs if at freeway speed 65-70 it keeps in the higher rmp not revved out just doesnt shift to over drive, when you let off throttle the rpms kinda drop but not at smooth as it would with the red lightening bolt sign off and running normal. When I cleaned my TB I cleaned my connectors and everything else is there a sensor I should consider it has been happening more frequently . Could the super chips be causing it?
Old 12-25-2013, 08:24 AM
Lake O Hunter Lake O Hunter is offline
Vehicle: 2004 Dodge Ram 1500 QC 4x4
Color: Gray
Lake O Hunter is on a distinguished road
So there is an existing recall for this on '04s?
