Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 05-20-2013, 02:04 PM
dschutz1979 dschutz1979 is offline
Vehicle: 1987 dodge d150
Trim Level: le 150
Color: red and white
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
dschutz1979 is on a distinguished road
Default carburator
How hard is it rebuild the carb? I never done one before and i want to do all the work to this truck. I've done a tune up and it still spitting and sputtering. its sat for about five years so i think it might have trash in it.
Old 05-20-2013, 08:34 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
i think it might depend on what carb you have. some are harder than others. i think most of the stock carbs could be a bit of a pain to rebuild but not impossible if you have patience. if is has something like a aftermarket Holley 4 barrel it would be super easy to rebuild.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 05-21-2013, 12:32 AM
Trim Level: le 150
It has the holley 2 barrel
Old 05-21-2013, 09:56 AM
it probably shouldn't be too bad.
Old 05-21-2013, 07:26 PM
Pacheco911 Pacheco911 is offline
Vehicle: 1998 Dodge Ram 1500
Color: Dark Green
Pacheco911 is on a distinguished road
Are Edelbrock carbs easy to rebuild? 1406
Old 05-21-2013, 08:34 PM
i have not rebuilt on edelbrock carbs don't look too bad to rebuild. they just look more time consuming to take everything apart which may take patience. there is some video's on youtube of how to rebuild a edlebrock carb.
Old 05-21-2013, 09:00 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Yeah, they're probably the easiest 4V carb to rebuild. Based on the Carter AFB. Elegant simplicity.
Old 05-22-2013, 03:46 PM
Trim Level: le 150
There ia a round thing on the driverside of thw carb with a rod coming out of it. when i hive it gas the rod comes out and keeps the engine idle high for a minute or two. would it be ok to take that piece off. its not the choke.
Old 05-22-2013, 04:42 PM
Rep:85
Doesn't sound right, and no, without better identification I wouldnt remove it at this point.
Old 05-23-2013, 09:06 AM
Trim Level: le 150
Every time i push on the gas pedal the rod will come out and keep the engine idle high for a minute or two then the rod will go back in and let it idle back down.
