carburator - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 05-23-2013, 02:57 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
you could take it off for now but you would need to put it back on when you put the carb back together. it is computer controlled. truck may not run as good if is completely removed.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 05-23-2013, 06:03 PM
dschutz1979 dschutz1979 is offline
Vehicle: 1987 dodge d150
Trim Level: le 150
Color: red and white
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
dschutz1979 is on a distinguished road
Do you know what that piece is called and what the purpose of it is?
Old 05-23-2013, 07:21 PM
i think the name of the part is idle stop solenoid. they are commonly known as an "idle solenoid", they are correctly referred to as an "anti dieseling solenoid" or "idle stop solenoid". Their purpose is not to raise the idle, but to close the carburetor throttle completely when the key is released and prevent engine run on. The reason they came into being is from all of the emmisions equipment, heavy loads like A/C compressors, high output alternators that all require a higher idle speed to stay running. That idle was so high that something was needed to allow the carburetor's butterflies to close completely thereby eliminating engine run on. They were never designed to push the carburetor open on their own. Only to hold it in place until the key was turned off.
Old 05-23-2013, 07:58 PM
Trim Level: le 150
Thats what it does when i push the gas pedal the rod will come out and when i release the pedal it doesnt let i idle all he way back down. thanks for telling me what it was.
Old 05-28-2013, 10:02 PM
Pacheco911 Pacheco911 is offline
Vehicle: 1998 Dodge Ram 1500
Color: Dark Green
Pacheco911 is on a distinguished road
Sounds like the accl pump?
