Old 05-20-2013, 08:41 PM
dozier68's Avatar
dozier68 dozier68 is offline
Vehicle: 2010 Dodge Ram 4X4 Crew Cab
dozier68 is on a distinguished road
Default Trailer Light Issues
It has been awhile since I have been on here, but I am having an issue with my truck and I need some help. I don't have right turn signal, right tail light, or right brake light. I have checked every fuse there is to check and they are all working. So I then moved to check and see if I was getting power to the 4-pin connection at the back of the truck and I am getting power back there. After checking that, I made sure the male and female connections were clean and getting a good connection and it still isn't working. I have this problem on two different trailers and I am completely loss. Please help!!
Cherry Bomb Vortex with 5" tips, 20% tint up front, Truck Champ nerf bars, AVS Vent Visors
Old 05-21-2013, 09:14 AM
thekid0311 thekid0311 is offline
Vehicle: 2005 Doge Ram Quad cab 4x4
Trim Level: Daytona
Rep:15
thekid0311 is on a distinguished road
I would check the grounds. well on second thought you wouldn't be getting power to the left brake light unless they have separate grounds. Do you get power to all the pins? It may just be the plug if you don't have separate grounds or it could be a loose connection where the plug wires splice into the right taillight and turn signal. Ive had a similar situation with my travel trailer but none of the light worked on it until I went checking my connections and my ground wire had worked its way loose from the where I had grounded it out on the frame. That's just my best guess and hopefully someone else can give you better info.
Men will follow out of fear but will die over respect
Old 05-21-2013, 09:56 AM
Inferno10's Avatar
Inferno10 Inferno10 is offline
Vehicle: 2010 Ram 1500 Sport
Color: Inferno Red
Rep:12
Inferno10 is on a distinguished road
Check all of the grounds. It might not be a bad idea to remove each one, clean the contacting surfaces with some light sand paper, reconnect them and use some battery terminal spray to coat them. Trailer lights can be a real pain. If you still have issues after that, call around to your local hitch or camper shops, many of them will have testers made just for trailer harnesses. They might be able to point you in the right direction.
Old 05-22-2013, 11:09 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
It's got to be a ground connection. Considering two of the bulbs affected share common power with the left side the chances of having the same problem on two different trailers is too high.
Old 05-23-2013, 09:04 PM
dozier68's Avatar
I had to pull a trailer again the other night and I must have been mistaken. The tail light is working but not the brake or turn signal.
Old 05-23-2013, 10:13 PM
Rep:220
It's still likely the ground, the brake light power is common to both sides, but have you checked the bulb?
