Old 05-20-2013, 09:44 PM
The1trugr81 The1trugr81 is offline
Vehicle: 2013 Dodge Ram 1500 Laramie
The1trugr81 is on a distinguished road
Default Headlights and Taillights
Thinking of changing to Projection HID headlights and Taillights. Anyone have any recommendations? 2013 Dodge ram 1500 Laramie...
Old 05-20-2013, 09:47 PM
Arth's Avatar
Arth Arth is offline
Color: Deep Cherry Red Crystal Pearlcoat
Rep:2028
I am confused. You have a Laramie correct?
You should have at least the Bi-Halogen projector headlamps and LED tail lamps.
If you are wanting to upgrade your headlight bulbs to HID there are many options for you to do so.
Chrome... in moderation.
Old 05-20-2013, 10:55 PM
I push the skinny pedal
Rep:3277
I'm with Arth on this one. If you have a Laramie then you should have the projectors already, and to add HIDs it's pretty straight forward.
Kurtis
Old 05-21-2013, 06:07 PM
Sorry as I wasn't clear. I am trying to change the look to black or gloss black from factory. Is there a particular brand other members can recommend? I know there is a lot of choices, just trying figure out a good brand that members are happy with.
Old 05-21-2013, 08:46 PM
Rep:3277
Ok, now we're on the same page. There's nothing available for the projectors in the aftermarket yet that replaces the entire housing, however, there is a guy who opens the oem housings, paints them whatever color you want, can upgrade the projectors as well, then seals them back up. His name is JJ with retroshop .us and he does good work. Both Arth and I have dealt with him in the recent past and he's a good guy.
Kurtis
Old 05-21-2013, 09:03 PM
Arth's Avatar
Rep:2028
I agree. I am currently getting an order filled through JJ to get the projector inside these 2013 headlights upgraded. I will create a thread with my review after I get them back.
Currently, as said above, that is the only way to "upgrade" your headlight unless you want to just add some HID's.
He does some great work and I recommend you check out his site.
Old 05-22-2013, 06:10 AM
Thanks for the info. I will check out his site.
Old 05-23-2013, 02:46 PM
audio1der audio1der is offline
Vehicle: 2012 Dodge Ram
Color: Dark Red Cherry
Rep:201
audio1der has a spectacular aura aboutaudio1der has a spectacular aura aboutaudio1der has a spectacular aura about
If you just want your existing headlights painted black, pull'em apart and paint them! It's not a LOT of work, but it is tricky.
An oven, a baking sheet, an old towel and a couple of flat blade screwdrivers.
'12 Ram 1500 4x4 Sport CC;Airlift 1000, Moroso air/oil can, S&B CAI & scoop, 87mm P/KE/P/TB, Jet 180, Magnaflow
Old 05-24-2013, 09:42 PM
Rep:3277
Don't forget the balls to pull apart $900 worth of headlight.
Kurtis
Old 05-24-2013, 11:49 PM
bighemi04's Avatar
Vehicle: 2014 Charger RT AWD
Rep:623
Great guy. Top quality products, customer service and craftsmanship
