Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2010 Dodge Ram Forum
Old 05-21-2013, 12:25 AM
Ferguda's Avatar
Ferguda Ferguda is offline
Vehicle: 2010 RAM 1500 4x4 Crew Cab sb
Trim Level: Lariat
Color: Inferno Red
Ferguda is on a distinguished road
Default Levelling lift question
Does anyone know if a levelling lift affects fuel mileage (positive or negative) or handling when towing over 3000 lbs of trailer?
Old 05-21-2013, 12:46 AM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
You could argue that it will affect your mileage slightly because levelling the truck does change it's aerodynamics. But will you notice the difference with only a level... no. It shouldn't effect your handling in any way either . If you use the Bilstein 5100 adjustables to level your ride quality will actually improve.
Old 05-21-2013, 01:20 AM
MangoTangoMofo's Avatar
MangoTangoMofo MangoTangoMofo is offline
Vehicle: 2010 1500 Sport 5.7L Hemi
Trim Level: Sport Quad Cab
Color: Mango Tango
Rep:98
MangoTangoMofo will become famous soon enough
Under normal driving conditions a leveling kit does not affect your handling and the effects on your mileage are very minimal. YET if you ONLY level your truck and then haul a heavy trailer your front end will feel a bit floaty and your headlights will be squirrel hunting in the tree tops as you drive. That is why I also went with a 1.75” rear coil spacer so my truck still has a bit of rake to it and the front end doesn’t go so nose high when I load the bed with firewood.
However don’t let you this deter you from leveling your rig. If you like the leveled look you can always get an airlift 1000. It will prevent your rear end from sagging and improve the handling of your truck by stiffening your rear suspension when you’re carrying a heavy load… that will be my next mod.
5x11x22 Magnaflow with a resonator delete // Rough Country 2.5F&1.75R level kit // 17 XD Cranks // 35x12.5x17 Toyo MT's // Air Lift 1000 // Armor Thane bed liner // Century Ultra Sport Canopy // Yakima Roof Rack // Mopar side steps // Custom Browning Mudflaps
Old 05-21-2013, 11:12 AM
Ferguda's Avatar
Trim Level: Lariat
Color: Inferno Red
Thanks for the info and quick replies.
Old 05-21-2013, 11:23 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
both very good replies ^^^^^^€€€
levelling kit
