Old 05-21-2013, 12:04 PM
rjmlakota's Avatar
rjmlakota rjmlakota is offline
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:18
rjmlakota is on a distinguished road
Default Going from 3.55 to 3.92 gears
I'm kind of disappointed I didn't go with the 3.92 gears. Can anyone tell me what it would cost to have the dealer update my 2013 Sport to 3.92 gears? Would there be any issues with moving to the 3.92 gears?
Thanks,
RJ
Old 05-21-2013, 12:23 PM
Moderator
Rep:2140
Do you have a 4wd or 2wd?
If you have a 2wd the swap will be fairly simple. All that needs to be changed is the ring and pinion in the rear diff. If you have a 4wd it's a different story. You can't change the gears in the front diffs from '12 and up. So you will need to get a front diff from a 09-11 and then change the gears in that. It ends up being a fairly expensive mod. You're looking at a couple grand for sure.
Old 05-21-2013, 12:59 PM
Rep:2890
If you only have 2 wheel drive & not a 4X4, it is not that big of a thing
IT IS ONLY MONEY
It was much easier to do in vehicles before the 2011 Rams when the ZF rear end started being built. The older differentials were made by AAM
May i ask why you want to go from the 3.55 to the 3.92
Do you Drag Race or pull a Trailer over 4,000 pounds ?
If you drag race, you will also NEED the LSD, (limited slip differential), for 2 wheel traction
In the Northern States, LSD sure comes in handy in the winter months
You can have LSD in any drive ratio, 3.21, 3.55, or 3.92
It was an Option with all of them in 2013
Old 05-21-2013, 01:14 PM
rjmlakota's Avatar
Rep:18
My 2013 has 4x4.
Definitly do not race, those years are past me.
I will be towing a 12' enclosed snowmobile trailer in the winter months with two sleds and gear in the truck. In the summer months I usually have 2 kayaks on the top and gear. I'm also going to be purchasing 10 ply tires and I'm a bit concerned with the 3.55 (Brandon thanks for responding to my post on the tires).
Do I have to be concerned, or would I just be wasting money?
If the dealership did the work, would it still be covered under the manufactures warranty?
Old 05-21-2013, 01:19 PM
Moderator
Rep:2140
Honestly, unless you're going with larger tires like 35's or 37's I wouldn't bother with the gear swap. Especially only going to a 3.92. It's going to be too high of a cost for the gains you'll see.
As I mentioned in your other post about the tires. Since you are sticking with a relatively stock size (a tad smaller actually) you shouldn't see too much of a difference. Your 12' trailer and sleds probably doesn't weigh anymore than 3000 pounds (I'm completely guessing). You'll be able to handle that no problem. I recently pulled 4500 pounds with 35's and 3.55 gears with my 4.7 and it handled it fine.
Old 05-21-2013, 05:01 PM
gcscott's Avatar
gcscott gcscott is offline
Rep:1043
Thanks,
RJ
Total wast of money!
You would be better off trading in the truck cost wise. Also to much of mixing parts from year to year. You would not see much change in performance.
MODS LIST! WeatherTech Floor Mats (F&R), WeatherTech Mud Flaps (F&R), WeatherTech Window Rain Guards (F&R), AVS Bugflector II, Dee Zee Heavyweight Truck Bed Mat, LRV Protecta Tailgate Mat, IPCW LED Tailgate Light Bar, LedGlow SMD Blue Interior Light Kit (F&R), Dee Zee Tailgate Assist, SS Exhaust Tip, Cabin Air Filter.
Old 05-21-2013, 11:15 PM
Cat Daddy's Avatar
Cat Daddy Cat Daddy is offline
Vehicle: 2012 Ram 1500 4X4
Rep:68
Cat Daddy will become famous soon enough
Ok I am confused a bit if the 2012 and the 2013 Have ZF and 3.92 are available from dealer then why could you not swap 2013 to 2013 ? I saw the post from Fast when they did his differential swap and the ring and pinion came out with no issues....I would say that the swap is not a big deal just dealer parts only no after market
20X9 Black XD Hoss with painted caps 275x65x20 NittosTerras,Bilsteins 5100's @ 2.1, .75" in rear,laminx tinted head lights,tinted tail lights & 3rd brake light, S&B,Fastman 84 TB,18' Magnaflow,T1000-hemifever,cabin filter,RECON led cab lights,custom dynamic 60" light bar,tow hooks,debadged ,6" shorty ,painted grill and front and rear emblem , AMP power step ,F1 Bacflip bed cover ,Mopar bed rug kit
Old 05-21-2013, 11:27 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
gears and labor times two axles for only going from 3.55 to 3.92. your money
Old 05-22-2013, 10:44 AM
rjmlakota's Avatar
Rep:18
Yeah, I'm just going to deal with it. My next Ram will have 3.92's!
Thanks for all the replies.
Have a great holiday weekend guys!
RJ
Old 05-22-2013, 02:27 PM
panelman61 panelman61 is offline
Vehicle: 2012 Dodge Ram 1500
Color: Deep Molten Red
panelman61 is on a distinguished road
I strikes me as odd that it can be so expensive to change them after the fact when it was only a $50 option on my '12 from the factory. Now I'd glad I paid the extra $50.
1.25 BL, 2.8 Bils, 1.5 Spacers, 20x10 Hostages, 35x12.5x20 Toyo's, 14" Magnaflow, 85mm TB, Vararam.
