Old 05-21-2013, 01:57 PM
Jake95's Avatar
Jake95 Jake95 is offline
Vehicle: 2013 ram sport 1500
Rep:29
Jake95 is on a distinguished road
Default Widest tire for air suspension
Does anyone know the widest tire without rub on an air ride equipped ram 1500
Entry exit rub it ok, I don't plan on driving in that mode
Old 05-21-2013, 06:58 PM
HorseMan's Avatar
HorseMan HorseMan is offline
Trim Level: Longhorn Crew 4x4
Rep:139
There are couple threads on this over in the tire and wheel section. You'll be cutting it close with anything wider than stock. You can go slightly higher, but not much-that's my impression anyhow. Let us know what you decide.
Even if you're not driving in entry/exit, you might want to think about accidental key fob hits, which makes the truck enter the entry/exit setting...you don't want a tire ripping off or tearing the fender plastic...just a thought.
Old 05-21-2013, 08:03 PM
Jake95's Avatar
Rep:29
Thanks for the info, I believe the accidental fob hit's wont matter when I'm driving over a certain speed, not positive yet as I don't have my truck but thought I read 15mph and it goes in normal. I keep seeing pic of the rams in exit mode and it look like it has a ton of clearance, then again pics are deceiving.
Old 05-21-2013, 09:57 PM
madhatr02's Avatar
madhatr02 madhatr02 is offline
MOPAR or no Car
Vehicle: 2014 Ram 2500 HD
Rep:145
madhatr02 will become famous soon enoughmadhatr02 will become famous soon enough
275/65/20 pretty much stock width and a little taller on factory rims. Anything wider and you will need aftermarket wheels. If you go that route then you can go wider as you can push the rim out a little.
Semper Fi,
Kevin
2014 2500 HD
aka "Big Red"
Old 05-21-2013, 10:07 PM
CLOTAGAMES CLOTAGAMES is offline
Vehicle: 2015 RAM 1500 CREW laramie 6'4
Trim Level: LARAMIE
Color: WHITE OVER SILVER
CLOTAGAMES is on a distinguished road
Running Cooper LTZ LT275/65/20 on stock wheels and that is max-can rub slightly at full turn
Old 05-21-2013, 10:29 PM
HorseMan's Avatar
Rep:139
I think the other guys are right. What I meant was, hypothetically, if you're parked in your drive and you hit the entry/exit button or a kiddo gets your remote and hits the button, and your tires are to wide, the truck will lower and rip your fender lining! I think too much.
Yes, when your truck hits a certain speed, it would raise from entry/exit automatically.
Old 05-21-2013, 11:31 PM
Jake95's Avatar
Rep:29
I would like to run the 275/65/20 or the 285/60/20 on a set of fuel nutz 20x9.
I can get a set at a good price, they are +1 of set. Do you think I would be ok with the 285. What offset would u recommend
Old 05-21-2013, 11:34 PM
Jake95's Avatar
Rep:29
To all that answered above, thank you and how are you liking the air ride. Are you regretting it or loving it. I'm nervous I made the wrong choice. But mi always like this, buyers remorse, until I drive it
Old 05-22-2013, 01:02 AM
madhatr02's Avatar
MOPAR or no Car
Rep:145
LOVING it hands down, no questions. The only reason I would even consider not getting it now that I have it is if I wanted to lift the truck. Right now you can't and doubt that you will ever be able to. But for a daily driven truck, that can tow comfortably and also handles better than most trucks you can't go wrong with it.
Also I drive in entry/exit mode in my companies parking garage and have no rub when turning on a FLAT surface. The only time I have had any rub has been backing out of my driveway which is steep and turning. Nothing that bothers or worries me.
Semper Fi,
Kevin
2014 2500 HD
aka "Big Red"
Old 05-22-2013, 11:09 PM
Jake95's Avatar
Rep:29
Got some good info from a few guys on here and a wheel shop. I've decided to go with the fuel nutz 20x9 + 1 offset with duratrac 285/60/20. After all the research I don't think I'll have a problem. If I do I will let you guys know so nobody else gets fooled like me.
