grinding noise still there - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-21-2013, 04:04 PM
Twinkeys0816's Avatar
Twinkeys0816 Twinkeys0816 is offline
Vehicle: 2006 Dodge Ram 1500
Twinkeys0816 is on a distinguished road
Default grinding noise still there
i have a grinding sound when turning the steering wheel to the left, it happens only when backing up the parking lot or getting off ramps and just turning at low speeds. i thought i had a bad wheel hub so i went and changed that this weekend and i still have the noise. also did the tie rod ends and the stabilizer links. what else could it be. could it be the cv shaft? ball joint? if anyone had the same problem and fixed it any help would be great. thank you in advance.
Old 05-26-2013, 01:32 AM
drumwzrd's Avatar
drumwzrd drumwzrd is offline
Vehicle: 2007 Dodge Ram 2wd
drumwzrd is on a distinguished road
Are you running any type of lift kit or just stock?
Old 06-25-2013, 01:44 AM
Clifford05's Avatar
Clifford05 Clifford05 is offline
Vehicle: 2005 Ram Pick Up
Trim Level: SLT Sport
Rep:20
Clifford05 is on a distinguished road
Ball joints, tie rods and end links will make a banging noise if bad, not a grinding. A axle makes a clicking if the outside joint is bad and a banging if the inside joint is bad, I believe. If it happens at real low speeds, have someone stand outside the truck and put it in reverse and cut the wheel and have them go to all four corners of the truck and see if they hear it more in one place.
As far as what it could be without being there I would have said front hub, mine went bad and it sounded like it was a rear end bearing when first starting to go bad. When it got real bad and was changed the next day cause it was so bad, it sounded like it was the front pass side, it turned out though to be the drivers side! I guess check the pass side and or I would check the driveshaft for movement, my one buddy has a bad pionion bearing in the rear diff. I would also check and remove caliper up front and inspect both inner and outter pad, caliper could be bad and not releasing and wearing pad down to backing plate on the inside pad and that could give you the grind noise. Good luck keep us posted!
Old 07-26-2013, 03:32 PM
ramhemi1985's Avatar
ramhemi1985 ramhemi1985 is offline
Vehicle: 2004 Dodge Ram
Trim Level: 1500
ramhemi1985 is on a distinguished road
Sounds like front driveshaft.. I have 6" fabtech lift gone through 3 driveshafts.
