Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 05-21-2013, 07:12 PM
Alaskan Hemisport Alaskan Hemisport is offline
Vehicle: 2011 Ram 1500
Alaskan Hemisport is on a distinguished road
Default Spyder Halo/LED install help needed!
I recently bought these headlights for my 2004 Ram 1500. I watched an install video brfore buying them, and it looked super easy, but the video didn't show all the wiring needed for the halos and LED lights. Does anyone know a link or how/where to wire in all that? I did some searching, but couldn't find much for my year.
Old 05-25-2013, 01:55 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
It is very simple. Don't be overwhelmed by all the wires that are loose. There are two sets of wires there, a hot (red/white) and a ground (black) They are there so you can connect the halo and LEDs to your running lights, all the hots connect to the same wire and all the grounds connect to the same wire. Use a twist on wire nut to connect all the hot wires together and add an additional 18g wire. Do the same for the ground wires. On the OEM wire harness, find the wire that becomes hot when you turn on your running lights, use a quick connect to connect the additional wire coming out of the wire nut to that hot wire. Then do the same for the ground wires, connecting them to the ground wire. Test and then install. Good luck and have fun!
