Backup camera help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior Modifications - Custom Audio / Video
Old 05-22-2013, 05:16 PM
BC18471's Avatar
BC18471 BC18471 is offline
Vehicle: 2011 Dodge Ram
Color: Gray
Rep:38
BC18471 is on a distinguished road
Default Backup camera help
I recently added a Kenwood head unit and am looking to add a backup camera. I would like to use the Mopar tailgate handle with the built in camera because I think that would look cleanest and give the best angle. However, I am not sure what types of plugs Kenwood and Mopar use. The Kenwood has a Yellow rca plug designated for the backup camera video in. I have not been able to get a good look at the Mopar plug that goes into the head unit. Does anyone know if I would be able to use the Mopar tailgate handle with the Kenwood wiring harness? I did some searches here but did not find anything about this issue.
Thank you,
Brian
Custom Katzkin leather, Magnaflow 14" with Y, Mopar CAI, Moroso Catch Can, 180* t-stat, Switchback Front turn signals, All LED lighting, Kenwood DNX6180, Cabin air filter, Smoked Tails and 3rd, Audiovox backup camera
Old 05-22-2013, 05:19 PM
Moderator
Rep:2140
Subscribed!!
I'm definitely interested in this as well. Just installed my own Kenwood deck and thought about adding a back up camera to it but definitely want the OEM one for the tailgate. Hopefully that hooks up no problem.
If anyone has links to the OEM camera kit and harness that would be appreciated as well.
Old 05-22-2013, 06:10 PM
Rep:2929
i believe the MOPAR part # is 82211184 but the sticker on the package reads 6803932 AC
this is one of this RamforumZ vendors, don't forget to mention that if you use them
http://moparonlineparts.com/1500-pro...em-p-2516.html
http://www.ramforumz.com/forumdisplay.php?f=133
here is a image of it, this sites price is too high
http://www.ebay.com/itm/NEW-2009-201...-/280952950645
Old 05-22-2013, 06:19 PM
imcanadianeh imcanadianeh is offline
Vehicle: 2009 dodge ram 1500
Color: red
Rep:30
imcanadianeh is on a distinguished road
I just bought a flush mount 170 degree backup camera for $35 and drilled a hole in the tailgate Handel where the oem camera would go. Camera works great picture is good, it likes like factory but was much much cheaper
Old 05-22-2013, 06:37 PM
Moderator
Rep:2140
Yes, I saw this. The instructions on Mopar Online Part's website aren't very good though, the pictures are all blurry. Do you know how it plugs in to the deck itself? And if you have an aftermarket deck to you still need the sales code added?
I like this idea! Do you have a link to the one you bought? And how as the install? Do you just have to run power to it and the video wire to the back of the deck?
Old 05-22-2013, 07:04 PM
BC18471's Avatar
Color: Gray
Rep:38
Thank you for the replies.
The problem I am having is that I had the RES (no screen) so I have no idea which connector the Mopar wiring harness uses. I can easily get the Mopar kit...but will that be able to connect to a Kenwood head unit that has the yellow rca jack designated for the backup camera?
Kenwood also has a kit, but that does not look like it would be easy to add to the tailgate handle. I am essentially asking if anyone knows of a way to take the Mopar tailgate handle with camera, and use the Kenwood wiring harness to connect to the HU...or the the Mopar harness is compatible with the Kenwood.
Old 05-22-2013, 07:08 PM
BC18471's Avatar
Color: Gray
Rep:38
Just checked, the Mopar wiring harness plug that goes into the HU definitely looks different...
Old 05-22-2013, 07:10 PM
Color: red
Rep:30
You can wire it many ways. I ran the video rca cable and the ground/power wire to the front of the truck and connected to wiring harness. Also since I have a PAC harness I hooked the reverse wire from my deck(pink) and hooked it to the reverse wire on the PAC harness(green)
This way the camera will automatically appear on the screen when I'm in reverse. Also with my deck I can turn the reverse camera on whenever that is gy I also ran it to a source tht is always putting out power
Old 05-22-2013, 07:12 PM
Moderator
Rep:2140
Nice, that sounds like exactly what I need. Do you happen to have a link to the camera you bought? Or even that brand?
Old 05-22-2013, 07:20 PM
Moderator
Rep:2140
OP look what I found! This is exactly what you need.
http://www.carid.com/2012-dodge-ram-...n-7464801.html
