Intake manifold replace - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 05-22-2013, 01:09 PM
TruckeeT2 TruckeeT2 is offline
Vehicle: 2014 Dodge Ram
Color: Maximum Steel Metallic
Rep:156
TruckeeT2 has a spectacular aura aboutTruckeeT2 has a spectacular aura about
Send a message via ICQ to TruckeeT2
Default Intake manifold replace
I have a 4th gen ram w/ 5.7L. I have a crack in my intake manifold. Has anyone had this problem? Is there a direct fit replacement upgrade?
2014 Dodge Ram 1500 Sport 4x4 5.7L HEMI
2014 Dodge Ram 2500 Laramie Longhorn 4x4 Cummins
2013 Dodge Dart Limited 2.0L
2010 Dodge Ram 1500 Sport 4x4 5.7L HEMI RIPP Supercharged (R.I.P)
2004 Dodge Ram 2500 Laramie 4x4 5.7L HEMI(FOR SALE)
1994 Chevy S-10 Blazer 4.3 Vortex (320,000+ miles)
Old 05-22-2013, 01:14 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Can you post pics of this crack and location? There is no direct fit upgrade all require a bit of work. Is the truck under warranty cuz a part like that would fall under the lifetime powertrain warranty go to a dealer and get it fixed for free...
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 05-22-2013, 01:18 PM
RamTex's Avatar
Color: Stone White
Rep:366
If you are looking to upgrade to a manifold that flows more than the stock one you will need $$$$! Just depends on if you want to spend $1600 or more for maybe 20 more hp....
Old 05-22-2013, 04:36 PM
Rep:156
No warranty. (Supercharged)
Don't want to spend too much more money, just did the tranny and supercharger.
I can get a stock one for around $300 and have a buddy of mine port it.
Old 05-22-2013, 08:17 PM
Ronan's Avatar
Ronan Ronan is offline
Vehicle: 2013 ram sport crew
Trim Level: Sport crew
Rep:42
Ronan is on a distinguished road
Isn't the intake manifold plastic??? How can it be ported???
ARH long tubes and y pipe,Vararam CAI, Moes 87mm, flowmaster, Edge 3000 stall,180 t-stat , e-fan swap, Ati 15% U/D pulley, Ebc rotors and pads, Diablo trinity w/ hemifever 93tune, 22" R/T's , bilsteins set at 2.1...for now ,lost the 35's, slimming down....
Proud member of LOCAL 361 IRONWORKERS
Old 05-22-2013, 08:56 PM
Rep:3347
If you are supercharged then you might want to look at swapping in the 6.1L manifold, depending on which supercharger you have. If you have a procharger it's easy, if you are running RIPP then you really can't unless you want to move a bunch of stuff.
Old 05-22-2013, 10:58 PM
Rep:156
Had my 2004 intake and heads ported, intake on that is plastic too they just grind it out.
I have RIPP
Old 05-22-2013, 11:05 PM
Rep:3347
Thermoplastic manifolds should not be ported, they don't have enough material to maintain proper structural integrity, especially when boosted when the material is put under tension as opposed to compression. I'm amazed that a shop would even touch a thermoplastic manifold. The heads you can port a whole lot, but you shouldn't touch the intake manifold.
The only part that could potentially be ported is the throttle body opening if you plan to run a larger bore TB, however, since you're boosted you don't need a larger bore TB.
I'm just trying to figure out why you'd want to weaken your manifold when you already have a manifold that's cracked under boost.
Old 05-23-2013, 11:31 AM
RamTex's Avatar
Color: Stone White
Rep:366
What year is the truck? If 09+ then go to Modern Muscle and talk to those guys about a fully ported 6.1 intake manifold and upgrade to a 90mm TB. if 08- then you got to get your crank case machined... or you will have to get the XV intake manifold.
Old 05-23-2013, 06:54 PM
HemiLonestar's Avatar
Rep:300
HemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the rough
The only non-plastic options are 6.1, XV or a custom welded sheet metal (the last one I saw done was going for about $1000).
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red"
2006 Charger R/T "Little Red", 2005 Magnum R/T
(Mods list in profile)
