Place your Ad Here!
Old 05-22-2013, 03:16 PM
retto22 retto22 is offline
Vehicle: 2011 Ram 1500 sport
Trim Level: sport
Rep:13
retto22 is on a distinguished road
Default muffler swap...extensive work?????
Just got back from carx..they said the muffler swap from stock to fm super44 will be extensive. They advised they need to weld hangars to support it. I explained the new muffler is significantly lighter and thus wouldn't need. They also want to weld extension pipe on the two exit holes. I said why don't you just weld one to the entrance side. How hard is this from experienced modders
Old 05-22-2013, 03:31 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
They are correct about welding new exhaust hangers. The stock hangers are on the back off the muffler therefore the pipes from the muffler back are support by that. When the muffler is removed there is no longer support. So that will need to be done.
As for the pipe extension, you are 100% correct. The extension should be on the front of the muffler, not the back.
Overall it's not that difficult of a mod at all. Any shop should be able to do it in about 30 mins max.
Old 05-22-2013, 03:34 PM
Trim Level: sport
Rep:13
Thanks for the reply! It helps me out .
Old 05-24-2013, 04:59 AM
Trim Level: sport
Rep:13
So the super 44 is installed and man does she purrrrrrr.. no drone.. great sound. . And a slight increase in mpg.
I'll post a YouTube link of the finished product. Maybe it will help others to see how it was completed.
