Old 05-22-2013, 06:09 PM
KA1OTE's Avatar
KA1OTE KA1OTE is offline
Ram Ham
Color: Mineral Gray Metallic
Rep:1475
Default Cargo Light Wire Location
I have an extra tailgate light bar laying around and was thinking it would be perfect to use in my bed for lighting. I would like to connect the reverse lights of the bar to the cargo lights in the 3rd brake light assembly - so whenever I engage the cargo light switch in the cab, the light bar (reverse lights only) in my bed illuminate with the cargo lights in the 3rd brake light.
Can someone tell me where I would find and how I would access the wire for the cargo lights in the 3rd brake light so I can t-tap into it?
Old 05-22-2013, 09:49 PM
Asur Asur is offline
Vehicle: .
Rep:4371
The wire is located under the door sills on the driver side, its part of the wire harness, I tapped into it just under the driver side rear passenger sill. Now you want to know what wire color, well I don't remember, but what I did was remove the 3rd brake light and looked at the color of the wires there, then went down to the door sill wire harness and found the wire, used a needle with a volt meter to find it, my wire for my bed lights comes in via the hole plug under the rear seat, so it was easy to tap in at that area. I think on my truck it was a white/light blue wire. Hope this helps.
Old 05-22-2013, 11:04 PM
KA1OTE's Avatar
Ram Ham
Rep:1475
Yep, that makes it more clear. Thanks for that. I think I have a better idea of what to expect and where to look. So, I run the reverse wire (light bar mounted with wire end oriented toward the cab) through a hole (that I need to cut?) in the bed, under the cab, and up through a hole plug under my rear bench seats and over to the door sill where I can remove the sill guard and find a loom containing the wire from the 3rd brake light assembly? Is this right? Will I need to run the 12V hot (red) wire from the bar to a power source (I am assuming, lol)? Is there a 12V source in the loom in the door sill? It would be nice to run the reverse and 12V wires together and tap both into the same location..
Old 05-22-2013, 11:44 PM
FSTASFCK FSTASFCK is offline
Vehicle: 2010 Dodge Ram Big Horn
Rep:108
FSTASFCK will become famous soon enoughFSTASFCK will become famous soon enough
I am pretty sure the wire is white with tan stripe...for 12v I would run it to the battery...
Old 05-23-2013, 12:54 AM
KA1OTE's Avatar
Ram Ham
Rep:1475
Thanks for the info! I'll be playing with this project this weekend..
Old 05-23-2013, 09:42 AM
Vehicle: .
Rep:4371
Depending on where you place your light bar you can use the holes at the top front of the bed to bring your wires out, you will need the "white" wire from the light bar (+) and the black wire (-), run these 2 wires down the inside of the fender of your bed (accessed from the hole I mentioned) down and under the cab, bring the wires in via the plug, RTV silicon the wires to the plug where they pass as to keep anything from entering the cab. then connect the (black) wire to the body ground of the truck, usually you can just use a sheet metal screw on the inside of the cab under the carpet or find a body bolt and connect it to there with a wire connector, and then tap the white wire to the wire I spoke about. So now when you have tie wrapped all that up and its clean, you can press your unlock button and your bed light and your light bar will light. Very simple, this is how i set mine up. So often I need something in my bed under the tonneau at night and just press my unlock and it lights up the box. If I need it on for a long period, I press the button on the dash.
Old 09-04-2013, 02:00 PM
Mullett Man Mullett Man is offline
Trim Level: SLT Bighorn
Mullett Man is on a distinguished road
Default How'd this go?
Looking to do this same thing, using LED strip lights as the camper shell dome is pathetic.
I'm trying to A) identify the cargo light wire that is in the door sill (white with tan stripe?) and B) that the additional (less than 1 amp) draw does not cause the onboard diagnostics to shut the circuit off.
Also, I will be running a dedicated set of LED banks under the bed rails to a switch at the tailgate for additional light when loading/unloading for extended periods.
Hoping this thread isn't zombied out.
Thanks for sharing your findings!
Old 09-04-2013, 08:11 PM
Vehicle: .
Rep:4371
Have been running a set of bed lights linked to the cargo lights now for over a year with no issues, cargo lights + 8 LED units with each 8LED's in the and no issues. Hope that helps
Old 09-04-2013, 08:18 PM
Any chance I could get you to take a peek at where you tied into the cargo lamp circuit?
Many thanks.
Old 09-04-2013, 08:20 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
I tied my bed lights into the domes, my full mod thread can be found here.
Big Red my old 2011 Sport
