Old 05-22-2013, 09:29 PM
Speedogomer's Avatar
Speedogomer Speedogomer is offline
Color: Prairie Pearl Coat
Rep:12
Speedogomer is on a distinguished road
Default Alpine aftermarket system installed, some issues.
So I had an alpine mrp-f300 50Wx4 amp installed, with a memphis 6 channel line out converter, alpine type S 6x9s for the rear and alpine type s 6.5 components front.
My only issue is that the sound is just too bright. The highs, especially cymbals in music, are just too overpowering.
Any ideas on how to handle this? Treble adjustments don't seem to help, gain is set relatively low, and everything is connected correctly.
2013 Ram 1500,4x4 Quad Hemi Big Horn, known affectionately as "Ramona".
Old 05-23-2013, 12:09 PM
autokraftgt autokraftgt is offline
Vehicle: 2011 2500
Trim Level: big horn
Color: grey
Rep:31
autokraftgt is on a distinguished road
You can add some level of processing to your system...then you can adjust eq and take out some of the harshness from what you're hearing. Even a small 15 band or more adjustable eq can help....basically you will be backing off some of the higher frequency ranges....or replace components with something that has a warmer sound
Old 05-24-2013, 12:32 AM
Rep:12
Any suggestions on a warmer sounding set of components?
The sound in general is just hollow, tinny, and lacking bass. I do have the amp set to a high pass filter, filtering out below 70hz, as that's the low end of frequency response for the speakers.
The sound dosent "fill" the truck, you're very aware the soundis coming from the iindividual speaker locations. I'm wondering if the speakers need more power. They're rated for 80w RMS and I have 50w rms. Already it's too harsh, I hate to add more power and increase the harshness without gaining any miss and lows.
Old 05-24-2013, 09:04 AM
Vehicle: 2011 2500
Color: grey
Rep:31
Im running dynaudio's esotar 650's and their esotar 110's
And they are as warm and natural as you can get imo
They need to be installed correctly with a lot a dampening to get full potential
Rainbows are well known to be warm and very natural sounding
A soft dome tweeter is a must imo
But with. Both brands mentioned, you're looking at a completely different price range
Old 05-24-2013, 02:59 PM
Rep:12
$500 for just the mid bass is too expensive for my tastes. Any suggestions on a less expensive set up?
Old 05-27-2013, 10:38 PM
bolo1g2 bolo1g2 is offline
Trim Level: Crew Cab Big Horn
Rep:19
bolo1g2 is on a distinguished road
Check ebay. You can find the Image Dynamics CTX65cs for around 175. Lots of people on the car audio forum I'm a member of love them. Check youtube for reviews and distance tests. Lots of good info on them.
Old 05-29-2013, 05:09 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
I wouldn't filter the front. Run it full. What did you start with as a system? Did you have OE Alpine? Do you still have dash speakers? If so, eliminate (unplug) them. Then, you can play with tweeter locations. Some tweeters are just harsh. A lot of decent aftermarket passive crossovers have attenuation levels for tweets, but the Type S are pretty entry-level. Where are your tweets mounted?
If you decide to chose a different set of comps, chose one that has variable tweeter levels at the cross-over, and make sure it's a -xdb, and not +xdb. Play with tweeter position before permanently installing. They will sound harsh if mounted in dash.
Old 05-30-2013, 10:52 AM
Rep:19
Sometimes tweeters and mids need to break in.
Old 05-30-2013, 11:38 PM
Rep:12
Started with the standard, non-alpine system. The tweeters are mounted where the 3.5 dash speakers used to be.
I'm thinking of moving the tweeters to the doors and see if that helps, as low as that is though, I hate to have the sound coming from below me.
Without the high pass filter, the bass is too variable. On some songs it's fine, on other types of music it distorts very badly, to the point it's completely unable to be listened to.
The sound itself is clear enough, just the highs are overpowering. I'll have to look into new crossovers or a new set of comps I guess.
