Old 04-24-2013, 08:17 PM
GAltima GAltima is offline
Vehicle: 2010 Ram 1500
Rep:40
GAltima is on a distinguished road
Default Just Installed Backup Camera
So i decided to pull my rear seats out to start making plans for my rear seat mod for my new stereo. As long as the seats were out i decided to finally hook up the backup camera that i purchased a while ago. When i installed my head unit back in February i ran the video cable to the rear of the cab already. I purchased the Audiovox CMOS2 for $60.
Started by pulling back the carpet under the passenger side rear seat and drilling a hole through a plastic grommet in the floor and feeding the cable through. I put some flex loom over the wire and ran it through the frame to the rear of the truck. Glad i had a fish tape lying around the garage.
Spliced the power and ground wire into the trailer plug wiring and ran that to the grommet going through the bed of the truck. Hooked the positive to the reverse wire and the ground to the ground wire.
I drilled a hole through the tailgate handle in the factory location just big enough for the camera to fit in. This camera fits great and looks factory.
Zip tied the wires out of the way and finished up with the adjusting of the camera to make sure the picture was straight.
DISCLAIMER : No children were injured during the testing of this product.
Old 04-25-2013, 12:14 AM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
Looks great! A very clean install.
Old 04-25-2013, 10:19 AM
MBR MBR is offline
Vehicle: 2010 Ram 1500 Sport
Rep:66
MBR will become famous soon enough
how do you like the Kenwood DDX-719 receiver? Looking at one for my wife's truck
Old 04-25-2013, 10:29 AM
Rep:40
I love the Kenwood. The only thing that i don't like is that it's not compatible with the android phones, only the Iphone. I can still use my Pandora Radio with the bluetooth though which still works awesome. This head unit is super fast and has great user customability.
Old 04-30-2013, 06:24 PM
FSTASFCK FSTASFCK is offline
Vehicle: 2010 Dodge Ram Big Horn
Rep:108
FSTASFCK will become famous soon enoughFSTASFCK will become famous soon enough
Just picked this camera up to replace the one I had...been wanting to mount it in the handle!
Old 05-01-2013, 07:26 PM
mlc317 mlc317 is offline
Trim Level: Slt Quad Cab
Color: Brillant Black
Rep:16
mlc317 is on a distinguished road
I just installed the same camera, how did you adjust the camera to make sure the picture was straight? Does your stereo go to camera mode automatically, if so how did you get it to do that, I have to switch modes before I backup, thanks for any help you could give
Old 05-01-2013, 08:20 PM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
awesome work bro ....def rep points for that !!
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter,SuperChip
Old 05-02-2013, 02:22 PM
Rep:40
After i installed the camera i put the parking brake on and turned the truck's ignition to the on position so i could shift into reverse without actually starting the truck. I had the tailgate up with the access cover removed so i could stand in the bed of the truck and see the screen on my headunit through the rear window. Now i could turn the camera to the right position while tightening it in place. I have the PAC wiring harness for my head unit so it automatically knows when i shift into reverse. There was a setting on my headunit also to automatically pop up the screen when i shift into reverse.
Old 05-02-2013, 02:27 PM
Big Boi's Avatar
Big Boi Big Boi is offline
Vehicle: 09 Hemi 1500
Trim Level: BigHorn
Big Boi is on a distinguished road
Thx for the info. Any advice on what spec the radio has to be in order to work with this camera? I.E. inputs
Old 05-02-2013, 05:38 PM
Rep:40
This camera has a video output (RCA) and a positive and negative wire. Preferably the headunit would be made for a backup camera so that it would switch screens when shifted into reverse, but as long as it has a video input this camera should work.
