Old 05-23-2013, 12:36 AM
biggmann biggmann is offline
Vehicle: 2006 Dodge Ram
biggmann is on a distinguished road
Default Unlock all doors?
I am looking how to set up my remote to unlock all the truck doors and not just the drivers door. I know I can push the button twice but I have an after market remote and pushing it twice jst re arms the alarm.
Old 05-23-2013, 01:10 AM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
I would check with your installer. Sounds like it might need to be programmed from the alarm to do that.
Old 05-23-2013, 01:25 AM
Canadian Hemi Pride's Avatar
stance makes her dance?
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
You might be able to adjust it just by looking through your owners manual. I know my truck keeps all doors locked after I turn the truck off until I open my door, and there is a few other settings. Should be able to change the settings, if not.. your best option would be a reprogram.
Tow mirrors up for the haters
Old 05-23-2013, 07:56 PM
HemiLonestar's Avatar
Rep:274
If it's the stock keyless remote then its in the owners manual or you can easily look it up online.
"Big Red"
2006 Charger R/T
Old 05-23-2013, 08:02 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
This is from the owners manual (found it online). I believe it said it was from an 08 but it should work on your truck as well.
The system can be programmed to unlock all the doors or
drivers door only upon the first UNLOCK button press
by using the following procedure:
1. Perform this operation while standing outside the
vehicle.
2. Press and hold the LOCK button on your key fob.
3. Continue to hold the LOCK button at least 4 seconds,
but no longer than 10 seconds, then press and hold the
UNLOCK button while still holding the LOCK button.
4. Release both buttons at the same time.
5. This will allow you to unlock all doors on the first
press of the UNLOCK button.
6. To reactivate this feature, repeat the above steps.
Old 05-24-2013, 06:20 PM
Rep:220
I think the OP said he is using an aftermarket remote.
Old 05-24-2013, 06:35 PM
Rep:2026
Definitely didn't read that first time I saw it. Not sure if the procedure I posted previously will work then.
OP, is it just an aftermarket remote or a full aftermarket alarm system?
Old 05-24-2013, 06:50 PM
Rep:2620
On my newer '09
i believe that i can set the number of doors that unlock, ( drivers door or all 4 ), in the EVIC
if you have that function set up, it should not matter if you are using the stock or aftermarket setup
Old 05-24-2013, 07:18 PM
Rep:274
Ah, missed that. Then you will need to consult any paperwork or the company that made your setup.
"Big Red"
2006 Charger R/T
