Old 11-26-2014, 03:18 AM
JsnMR2 JsnMR2 is offline
Vehicle: 2015 Dodge Ram 1500
Rep:16
JsnMR2 is on a distinguished road
Default 2015 Ram 1500 - Method Mesh Wheels, Backspacing?
Hello everyone..
Ordered my Ram 1500 Laramie CC/SB EcoDiesel... Researching which wheels to purchase..
Looking at the Method Mesh wheels. They are new for 2014.
http://www.methodracewheels.com/coll...sh-matte-black
I am looking at a 20" wheel and 35" tire.
The question is... They only offer one back spacing option in 5 Lug. 5.75" or + 18mm. Will this work? I'm new to Dodge so I really don't know, but if my gut serves me right, these will be sunk in way to far? Sort of like stock, no?
I like the "NV" as well, but the backspacing available in 5 lug is 6" here or +25.
All of that said, what backspacing/offset is perfect for just a little poke? Thinking no more then 1"
20x9 inch wheel and 12.50 tires.
2015 Ram 1500 Laramie CC/SB Diesel
Bilstein 5100-Zone UCA-20x9+1 Fuel Boost-305/55/20 Duratracs
Old 11-26-2014, 12:48 PM
Rep:2117
Before I even get into everything regarding wheel sizing and offset I need to ask one question. Did you order your truck with air suspension or without?
Old 11-26-2014, 04:03 PM
Rep:16
No air suspension. I plan on installing a 4" lift.
Old 11-26-2014, 04:32 PM
Rep:2117
Okay, you will need the lift (or a level) to fit 35's. A 20x9 +18 offset won't work to fit 35x12.5's You'll need at least a 0 offset to avoid rubbing on the upper A-arm. You can go with more of a negative offset if you want a wider stance. The majority of guys run 20x9 0 offset or -12 offset. I'd suggest looking through some of the stickied threads in the lifting section of the forum to see what the different setups look like and determine what you want.
Old 11-26-2014, 04:39 PM
Rep:16
Thanks. Bummer, I like those wheels...
