Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy
loads with coil springs
. Fits all 2009-15 RAM 1500 including Ecodiesel and 2014-15 RAM 2500!
No modification required
; keep the coil springs. TLC also makes units for 02-13 RAM 2500 & 02-15 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™. Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 05-23-2013, 06:40 AM
dankent's Avatar
dankent dankent is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Trim Level: Laramie Limited
Rep:32
dankent is on a distinguished road
Default Great system while it lasted
Well i had some issues with the rubber pads staying connected to the airbags which was causing them to move arround on the drivers side:
even with air in them about 5-10 all the time and 20 - 25 when trailering. I wasnt sure if this could cause other issues eventually as it looked awkward. Passenger side seemed for the most part fine.
Normally in the past i had no problems with customer service .. this time .. i emailed .. nothing ... then emailed again .. was told someone would email me back the next day .. nothing ... once again i email (a month later) and didnt get an email back .. a couple days after this i get a phone call from someone with a different company name, but being suspension related i assume it was reguarding my issue and wanted to know what the problem was.
Well no need to bother anymore, i sold the truck and upgraded to a 2500.
Keep an eye on them is my point Happy trailering !
Old 05-23-2013, 09:20 AM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Dan,
Please let me look into this. We strive for great customer service.
John
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 05-24-2013, 12:49 PM
TLC John's Avatar
Rep:17
Dan,
Sorry we fell down on getting back to you. We had an internal communication snafu that I should have made sure didn't happen. We work to have great customer service but that didn't happen here.
The pics do not show any functional problem with your unit nor did we hear that from you.
Since your unit was purchased, we have gone to a different arrangement with the air bags mounted on the top frame. The previous design mounted the air springs on the bottom. We also now use different pads that are standing up.
Hope you enjoy your new truck and that we can serve you again in the future.
John
Total Load Control™
