Old 05-23-2013, 03:31 PM
Scottyr33's Avatar
Scottyr33 Scottyr33 is offline
Scottyr33 is on a distinguished road
Default Will Grand Cherokee wheels fit on 1500 ram?
Does anybody know if a 20" rim (5 lug) rim that was on a Grand Cherokee fit on my 2010 1500 ram? Unsure of lug patterns?
Old 05-23-2013, 03:44 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
I know the Ram wheels are 5x5.5 (139.7) bolt pattern but I have no idea what the Cherokee wheels are. I'm sure you could google that no problem. Then the offset will also play into it a bit. The stock Ram 20" wheels are +19 offset so you would have to have that or lower.
Old 05-23-2013, 03:58 PM
Scottyr33's Avatar
Ok, let me go hit google, thanks for the info Brandon
Old 05-23-2013, 04:13 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
You probably found it already but I'm pretty certain the Cherokee rims are 5x4.5....not gonna work.
Old 05-23-2013, 04:49 PM
blacknchromehemi's Avatar
blacknchromehemi blacknchromehemi is offline
Vehicle: 2012 ram 1500
Trim Level: big horn
Rep:14
blacknchromehemi is on a distinguished road
im almost positive jeeps are 5x5
Old 05-23-2013, 05:17 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
http://www.wkjeeps.com/wk_wheels.htm
Old 05-23-2013, 05:26 PM
Rep:2616
http://www.roadkillcustoms.com/hot-r...ers-Finder.asp
2002 - 2011 or 2012, when Fiat took over, i believe there was a change over to a METRIC STUD THREAD
DODGE RAM 1/2 TON TRUCK 2 & 4WD Metric: 5 X 139.7
Standard: 5 X 5.5
9/16-RH <---- Stud size & S.A.E. STUD THREAD
77.8 <----- centerbore
Jeep
1999 > JEEP GRAND CHEROKEE Metric: 5 X 127
Standard: 5 X 5 16 X 7 1/2-RH 71.5
Old 05-23-2013, 05:43 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
No, but the previous gen Durango/Aspen will. They used a 5-139. As stated above, the current JGC (WK2s) use 5-127.
Old 05-23-2013, 06:29 PM
Scottyr33's Avatar
I'm thinking they won't fit! Thanks everybody for the input
