DIY Headliner and trim color change - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 05-24-2013, 12:53 AM
msorbara10's Avatar
msorbara10 msorbara10 is offline
Vehicle: 2004 Ram 2500 Hemi QC
Rep:41
msorbara10 is on a distinguished road
Default DIY Headliner and trim color change
What up everyone. I been waiting to do this mod for a while and finally got around to it. I hated the two tone tan and black and wanted to make my interior all black. I have seen this done on the forum before but figured I would try to make a detailed one to help whoever is looking to do this.
You will need:
foam headliner ( I got mine off ebay and it came with the glue I needed. I got 120"x60". This was the perfect size because it left me extra material to do the visors which I am just finishing up.
glue for the liner ( Will show a pic later on)
ratchet and sockets
screwdrivers different sizes
different wrenches
wire brush
allen wrench
led bulbs if you wish (Got superbright led's on the way)
duplicolor plastic and vinal spray paint (2 cans)
big sheet of cardboard or anything to keep spray off ground
a little help couldnt hurt
patience
a little beer will help
ok first what I did was take off the tan moldings.
Just pry the holed open with a screw driver and use a 10mm socket to get the 2 screws out. Also do this for the back 2 handles. These two pillars were a little tricky to get off. In the front by the windshield and on the dash there are 3 inserts where it is still connected and takes a little playing around to worth them free.
Next go to the back and take off thoes 2 handles just like the first but the handles come off seperatley. Then take off the cap that is on the seatbelt and take an allen wrench and screw that seatbelt off. From there it is eay to pop off that molding.
Do the same for the back now
These little clipes are on all of the moldings but on the back one there are three of them which makes getting them out a little difficult at first but once you know where all of them are you can just pop them right out.
next pop the covers off the map lights and there will be 2 screws in there that you unscrew and this will allow the unit to hang down. there are 2 clips on the back of it, they are easy to find and that will help you get it down.
from there there are 2 wires that are clipped into the units, just unclip the white one first bc it is easier. the black one I had troubl with so I unscrewed the screen from the unit and this actually made it easier to spray the unit later on.
Take out the screen for the dome light and then wiggle that down. There is also a wire that clips onto that unit as well and just unplug that and take it off
Next unscrew the 3 screws on you visors and pull them out. Mine dont have anylights on the mirrors so I didnt have to worry about any wires in there. For the other hooks that are there, grip the botton of it and pull down. This will seperate and make a big space in the hook. From there you can just pull them out. You can do the same for the clips in the back.
Next go to Home Depot and buy a husky toolbox for your truck so you can get cardboard to paint your plastic on.
When painting your plastic go in long passes across the plasitc longways. Do very very light coats so the paint gets a chance to stick to the plastics. I did like 6 to 8 very light coats. You will see if you go on to thick that it will look like it dosent want to stick to the plastic at all. Trust me spray it so it looks like you are hardly putting anything on and keep going from there. it dries quick so just keep going around in a circle spraying every part so it goes quicker.
After you get all of the parts painted you can do the headliner. Once all the the clips and molding is removed the liner will come down.
You will see that there are 3 sets of wires that will be hooked to the headliner. There is one that will be in the back for the 3rd brake light and just unplug that, also the one in the middle for the dome light that had been taken off before, and also a set that runs down the drivers side door that the one panel was covering up. Unplug that as well and there are clips holding the wires onto the door and just pop thoes out. The wires are glues to the headliner so it is easy to figure out what one goes where.
Next you have to get the headliner out of the cab which was rough. I had to put the seats back and had to shift my truck in 4Hi because the liner kept hitting it. Hopefully you will have a better time getting it out then I did.
Start peeling off the headliner. You will not be able to get the foam off with the cloth and thats where the wire bruch comes in. You have to take that and scrape off as much foam as you can. The more you take off the better it will look because it will let the new liner stick better.
It takes a long time and this is when its good to have patience and beer. Also a little help switching on and off if you have it which I did not.
When you finish that, lay you liner on top of the board and then fold it half way over.
Take your glue and give it a good shake and spray it evenly on both the board and the new liner. Make sure you get the edges coated well.
this is a good video of how its done and this is how I did it.
When you glue it, lay the liner on evenly starting from the middle with you hand and rubbing to the edge. Be aware of the indents in the liner to make sure to allow slack to get into there. Let it sit and trim off the edges. I did not have anough glue in some parts on the edge because I ran out. A hot glue gun works great to fix this problem.
Next cut out the holes where ever there needs to be cutout so you can install everything.
Just put it in the way you got it out and you will be set.
Old 05-24-2013, 12:54 AM
msorbara10's Avatar
Rep:41
The pics dont do its justice but man it looks so much better. And doing it yourself really make the mod worth wild. It feels great doing that and being able to tell people you did that yourself and it looks great. As for the sun visors, I just got creative and wraped them best I could and hot glues the back where i could glue the fabric together. it takes a long time and I didnt even finish yet. But just get creative. If you got your mom, whife, or GF who wants to help take advantage of that haha
This whole process took me about 7 hours because i kept getting delayed by the rain and took me a little to figure some parts out
As you can see I dont got my LED's in yet but they are going to really make that pop. Make sure you get the Festoon shaped bulbs. I got the wrong ones thats why I have to wait a few days to get the new ones I ordered.
Old 05-24-2013, 10:26 AM
MattHicks2010's Avatar
MattHicks2010 MattHicks2010 is offline
Vehicle: 2008 Dodge Ram
Trim Level: Big Horn SLT
MattHicks2010 is on a distinguished road
That looks awesome! Nice writeup!
Old 05-24-2013, 04:10 PM
msorbara10's Avatar
Rep:41
Thanks man. It makes such a difference. I think a lot of people would like to do this because its cheap and can really have a custom feel to their truck
Old 05-25-2013, 07:25 PM
SI Integra SI Integra is offline
Vehicle: 03 Ram
Trim Level: SLT Sport
SI Integra is on a distinguished road
A+ Write up. Looks great!
Old 05-26-2013, 03:35 PM
msorbara10's Avatar
Rep:41
Appreciate that, Thanks!!
Old 05-27-2013, 02:22 AM
Clifford05's Avatar
Clifford05 Clifford05 is offline
Vehicle: 2005 Ram Pick Up
Rep:20
Clifford05 is on a distinguished road
Always been looking to do the same to mine, would always look at the dark dash and said would look cool taking the color up the pillars and to the headliner... just like everything else, NO TIME! Looks great nice work!
Old 05-28-2013, 01:05 PM
msorbara10's Avatar
Rep:41
Thanks man. Just take a weekend and start early and you canhave it done in a few hours. If you got someone to help scrape off the headliner then you can do the rest. The headliner took me the longest because it was in perfect condition making it hard to scrape off. But other than that its not too time consuming but I know what you mean everyone is busy these days
Old 05-28-2013, 01:35 PM
TonyG-'s Avatar
TonyG- TonyG- is offline
Vehicle: 2010 Ram 1500
Rep:192
TonyG- has a spectacular aura aboutTonyG- has a spectacular aura about
Great write up!
Old 05-28-2013, 05:59 PM
Raminator5280's Avatar
Raminator5280 Raminator5280 is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT Bighorn
Rep:56
Raminator5280 will become famous soon enough
looks nice. what kind of paint did you use. any clear coats?
DiabloSport Trinity w/CMR tune, K&N FIPK, 87mm ported TB, Dynatech LT Headers, Magnaflow cats, ypipe, & muffler, Jetstream scoop, diy ram air, push start
