My New VARARAM Install review - - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 05-27-2013, 12:49 AM
madhatr02's Avatar
madhatr02 madhatr02 is offline
Vehicle: 2016 Ram Rebel 4x4
Rep:145
madhatr02 will become famous soon enoughmadhatr02 will become famous soon enough
Originally Posted by asavet18 View Post
Do the active grill shutters affect the ram air's performance?
Nope, used mine as a test truck. There is more than enough air flow, and AGS is only on the top 2 rows the bottom is still open.
Semper Fi,
Kevin
2016 Dodge Rebel
aka Project Black Sheep
Old 05-27-2013, 04:00 AM
Murderedout1802's Avatar
Murderedout1802 Murderedout1802 is offline
Vehicle: 2013 RAM 1500 2wd express
Trim Level: EXPRESS
Murderedout1802 is on a distinguished road
Looks awesome I'm buying mine soon!!
Old 05-29-2013, 11:35 AM
Designflaw's Avatar
Designflaw Designflaw is offline
Vehicle: 2013 Ram 1500 4x4 Sport
Rep:40
Designflaw is on a distinguished road
Originally Posted by RyanJM View Post
Looks great and if the color bothers you depending on how comfortable you are painting it's really not a very difficult job to do. I paint for a living and have done a lot of under good parts custom for Vette and GTO owners mainly. That already being painted simplifies the process. Just shoot me a pm if you want and I will give you a quick how to and what to use to get a body shop finish for cheap money. Red paint is expensive but it is a pretty simple job you can do from start to finish in a day. Nice thing is you don't need any special tools or equipment.
I may do that but I figured that it can't be that much to drop off at a body shop that may be painting Red at some point.
Originally Posted by madhatr02 View Post
I love mine for sure. Don't think there is any true way to measure performance as there are so many variables, but it sure doesn't seem to hurt anything!!
I agree, plus it looks cool as crap when you open the sport hood!!
See above
2013 CC Sport 4x4: 3.55, 20% Tint, Line-X, fender flares, mud flaps, Weather Techs, bed cover, 2.5 Leveling kit, Blacked out emblems, Vararam Air Grabber
2008 M109R LE, 1999 TL1000R, 2003 Yamaha Golf Cart :hah:
Old 05-30-2013, 08:56 AM
velocityss1985 velocityss1985 is offline
velocityss1985 is on a distinguished road
Looks Awsome! Job well done.. Keep us posted on the performancve gains.
Old 07-31-2013, 10:27 AM
zj4x4 zj4x4 is offline
zj4x4 is on a distinguished road
@Designflaw - I hit the same things that you highlighted but I have a couple other questions.
I have a 2013 Hemi 8 speed, so I wonder if things are different compared to the 6 speed. There is an extra piece that connects to 3 holes at the bottom but it's not clear to me if it's needed because it doesn't seem to fit properly. The instructions stated that the front shroud wouldn't fit properly without cutting but I didn't find that to be the case. Here's the image with the shroud still attached:
If I take it off the air grabber is just kind of suspended and hits the top of the front radiator:
And here's how it looks if I attach the plastic piece that connects to the three holes in the air grabber. It's a little hard to tell from the photo but it is pushed forward by the radiator a bit. And again, it's not even mentioned in the instructions that it should be attached.
What is the correct way to install that piece, and does it matter if the front shroud is on or off? It's not even mentioned in the instructions and seems out of place when I have it installed.
Old 07-31-2013, 10:37 AM
Ramops Ramops is offline
Vehicle: 2013 Dodge ram 1500
Rep:15
Ramops is on a distinguished road
Here I come Varaaam . Thanks for the write up
Old 07-31-2013, 10:57 AM
Vararam Industries Vararam Industries is online now
Vehicle: 2012 Dodge Ram
Rep:41
Vararam Industries is on a distinguished road
The shroud should be removed as per step 5 in the instructions to allow for proper intake airflow.
Some customers will cut the shroud out around the air inlet area. If you choose to do this , make sure your cut is 2 -2 1/2inches x the full width of the unit.
If you have any questions give us a call 832-701-7700
Old 07-31-2013, 11:05 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:782
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
subscribed...........
Old 07-31-2013, 11:19 AM
Got it, so the point of that piece is to direct air upwards into the intake. Makes sense. I also see now why the instructions mention moving the wiring harness - it's not a clearance issue, it's an airflow issue. That line is right in the way. Is that correct? If so the OP might want to adjust his.
Old 07-31-2013, 11:32 AM
Actually I wonder if this is applicable to my vehicle, which has the active shutters in the front. I don't have another place to locate that wiring harness.
