Old 05-24-2013, 01:25 PM
tigman175 tigman175 is offline
Vehicle: 2013 Ram 1500 Quad Cab
Color: Maximum Steel
tigman175 is on a distinguished road
Default 2013 quad w 35's work?
Ive been reading and reading and keep seeing different opinions. My plan is to put a 2.5 leveling kit on my truck and run 35's. I am lookin at getting 8.5" wheels with 15mm offset. Can anyone tell me if i will need flares or if i will rub?? Thanks
Old 05-24-2013, 03:30 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2051
I'm not 100% sure as that is quite a different offset than what most people run but I think you'll be okay. With that offset you'll have rougly 5.3" of backspacing. Guys with the stock 20x9 wheels running 1/4" spacers are at rougly 5.5" of backspacing. So you'll clear on the inside. If you do have any rubbing it would be very minimal at full lock on the sway bar. You should be tucked under the wheel well no problem too so you won't need flares.
Old 05-26-2013, 10:51 AM
teaff1979's Avatar
teaff1979 teaff1979 is offline
Vehicle: 2013 RAM Lone Star 1500 4x4
Trim Level: Lone Star
Rep:34
teaff1979 is on a distinguished road
thanks guys can someone give me a link to some good 1/4" spacERS that will fit a 2013. I hear the lug size changed? Anyways let me know cause I just ordered some new 35"s
Bilstein 5100 at 2.1, Cherry Bomb extreme. 35 12.50 20 Courgia M/T 6" Zone lift 5" rear coils.
Old 05-26-2013, 10:53 AM
teaff1979's Avatar
Rep:34
Sorry I posted on the wrong thread lol but still need help
Old 05-26-2013, 04:58 PM
Rep:2051
Rough Country makes them. Check out their website.
Old 05-27-2013, 01:36 AM
mattman13 mattman13 is offline
Vehicle: 2012 Ram 1500
Trim Level: slt big horn
Rep:44
mattman13 is on a distinguished road
35x?x? those can make a lot of difference in what your gonna fit. Also brand and type. Some tires are 35x12.5 and actually 13 wide in section and so forth.
I'd just go with like a 0 offset or - but I prefer wide stances.
SPONSORED BY: bULLY'S pERFORMANCE
Old 05-27-2013, 11:54 AM
teaff1979's Avatar
Rep:34
35x12.5x20 Federal Couragia M/T I cant get new wheel as of now but will one day.
Old 05-27-2013, 12:01 PM
teaff1979's Avatar
Rep:34
also should i get 2 or 4?
Old 05-27-2013, 12:02 PM
Rep:2051
The Federals come in at about 34x12 when they're actually mounted. You'll be fine with just 1/4" spacers. My cousin is running that exact set up and only rubs on the sway bar at full lock.
EDIT: What do you mean get 2 or 4? Wheel spacers? Definitely all 4 wheels need spacers. The back axles on these trucks are already set in 0.5" further than the front. There'd be an even bigger difference if you only put spacers on the front.
Old 05-27-2013, 12:20 PM
teaff1979's Avatar
Rep:34
2013 ram 1500 is a 5 on 5.5 correct?
