bigger tires - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-24-2013, 04:00 PM
ADA16 ADA16 is offline
Vehicle: 2012 ram 1500
Trim Level: express
Rep:43
ADA16 is on a distinguished road
Default bigger tires
Ok, before i pull the trigger on the tires, i want to make sure, will 275/65r20 duratracs fit with no problem, with the 5100s set at 2.1?
Old 05-24-2013, 04:09 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
you'll be fine......
Old 05-24-2013, 04:13 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Yup, you'll clear those no problem. They come in at 34"x10.8". There are guys running full 35x12.5's with Bilsteins at 2.1" so you're golden.
Old 05-24-2013, 04:30 PM
Trim Level: express
Rep:43
SWEET!! Also i keep hearing about 4wd shudder, should i be worried about this with the shocks at 2.1? Also even if it does happen is it a serious problem or just annoying when accelerating?
Old 05-24-2013, 04:32 PM
Rep:1900
don't worry about it. if it does happen to you, it's usualy just on flat ground on acceleration and isn't that bad. I'd be more worried about it if u went 2.8 but ull be fine
Old 05-24-2013, 04:35 PM
Moderator
Rep:2140
Yup, what gonefishin776 said ^^
I'm running a 2.5" leveling kit and haven't had any issues whatsoever. I'd say it's a rather small percentage of people that do get the 4wd shutter.
Old 05-24-2013, 04:37 PM
Rep:1900
I Agree. I get it with my bilsteins maxed. but it's minor and only
when on flat surface...like hard packed snow. offroad on dirt and mud it doesn't do it...well I guess it does u just can't feel it
Old 05-24-2013, 05:13 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:418
I have 275 65 20 on mine with Bills at 2.8. No issues
Old 05-24-2013, 11:08 PM
Trim Level: express
Rep:43
Sounds fine to me! Thanks everyone for the help!
Old 05-24-2013, 11:44 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Zero issues running those tires as its so close to stock
sales@revelperformance.com
