Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 05-25-2013, 07:35 AM
kampincrazy kampincrazy is offline
Vehicle: 2005 Dodge Ram 3500
Color: Blue
kampincrazy is on a distinguished road
Default truck shutter, vibration, shakes
I don't know how to describe this but when I take off from a stop my truck shutters,shakes it does it not towing my camper but it is more noticeable when towing my 35' 8800 lbs travel trailer. It is ok once it get going it just happens from a stand still. any ideas would be great
Thanks
the truck is 2005 3500 single rear axle diesel
Old 05-26-2013, 10:51 PM
thekid0311 thekid0311 is offline
Vehicle: 2005 Doge Ram Quad cab 4x4
Trim Level: Daytona
Rep:15
thekid0311 is on a distinguished road
Sounds like a erg valve. I may be wrong so don't quote me. My truck did the same thing and it kits a code eventually but it progressively got worse. Someone else might have a suggestion but that's they best Ive got.
Men will follow out of fear but will die over respect
Old 06-13-2013, 02:29 PM
jerrykatz jerrykatz is offline
Vehicle: 2005 Dodge 3500 4X4
jerrykatz is on a distinguished road
Does it feel like engine or driveline? I have not had any issues with my egine or electronic sensors. I would first check the towing brake to see if it is properly adjusted so that the brakes on the towed vehicle is not locking. If not that, then I would check the center support bearing on the drive shaft (if you have one). Good luck.
Old 06-13-2013, 04:22 PM
Color: Blue
UPDATE
I took the truck to merlins they couldn't see anything and didn't notice anything when they drove it, Next I took it a small diesel mechanic shop to have the Edge Insight Monitor installed when he drove it he said it was the rear u-joint so I took it do a dodge dealer to have it check because I have an extended warranty
it was the rear u-joint they replaced it the shakes are gone.
