Considering 5th wheel options - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 05-25-2013, 11:04 AM
Deathrend Deathrend is offline
Vehicle: 2015 Ram 3500 MC DRW
Color: Maximum Steel
Engine: 2015-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 865lb/ft (Aisin ASC69RC Automatic)
Rep:68
Deathrend will become famous soon enough
Default Considering 5th wheel options
So I've been looking into fifth wheels for a while now, trying to decide on what I want, don't want, so on. The major thing I'm trying to figure out however is weight. If my math is correct, I'm going to max out to around 1500-1700 pin weight. Does that sound correct? Seems a little low. At the same time I'm seeing people state that 2,100 should be fine, so I really don't know where I should be looking.
At the moment I do have one in mind that has a very light pin weight (Due to the arrangement) which I actually like the layout of.
The GVWR is right around the limit, the pin weight however is around 400lbs shy of where it would normally fall with a 5er of this size. http://www.forestriverinc.com/FifthW...pe=fifthwheels
Thoughts?
2017 Tradesman 3500 CCLB 4.10
Torklift StabeLoads, SuperHitch, SuperTruss, FastGuns
2018.5 Lance 1062 Camper
Old 05-25-2013, 11:59 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:418
It says the trailer is 13,460 lbs. 10 to 15% of that puts you at your projected 1500 to 1700 lbs. Your truck according to Ram gives you plenty more than that so you should be more than good to go.
Old 05-27-2013, 11:44 AM
HorseMan's Avatar
HorseMan HorseMan is offline
Trim Level: Longhorn Crew 4x4
Rep:139
Thoughts?
Nice trailer. Do you have a fifth wheel hitch installed already? Just curious. I need one and not sure which brand to get. I love the forest river trailers!
Old 05-27-2013, 03:32 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
Read this post, and re-read the last sentence of the original posters comments many times, as no one seems to want to believe it when told.
http://www.ramforumz.com/showthread.php?t=142894
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 05-27-2013, 09:53 PM
Rep:68
I'm looking at 2500 ratings though, I know they aren't exact, I'm going more on GVWR (Worst case). If I was to go by the numbers they give, I would be looking at 18,000 lb GVWR campers with 2400 pin weight.
I'm trying to figure out what pin weight I should be good at. As my truck sits with three people in it, I have around 2500 lbs free on the back axle, I'm assuming 200-300 lbs of hitch, as well as +-10% of the given pin weight. I work on commercial scales for a living, so I know exactly how much people like to fudge numbers, be it on vehicles or otherwise.
As of which hitch, I'm leaning towards the Reese 18k with slider. I'm also considering a lower end Reese with sliders (Non below the bed mounted). The below the bed mounting is really nice, but it's almost double the price. Majority of the time I'll probably have a gooseneck hitch mounted to the rails however.
What it boils down to, I have to stay Sub 20k total GVWR, and sub 6k GVWR rear axle to remain legal. In most states I don't have to swat being weighed, but I still want to keep it under the limit. I also want the most bang for my buck, longer and higher end camper for less weight is a win in my book.
Old 05-27-2013, 10:49 PM
TRCM's Avatar
Rep:63
CHA-CHING !!!
It doesn't matter if the truck is a 1500 or 2500...the point was the people who make the trailers aren't really truthful in their empty weights, but most people still believe them when they say the truck can pull it to make the sale.
Old 05-28-2013, 09:46 AM
Rep:68
Empty and dry are two different things though dry weight is before they add.. interior. Most people think it's just the absense of water.
I like the front living plan 5ers, they seem to be rear heavy with the bedroom being in the back. Seems like you can get a longer camper for less weight up front.
It's just a lot of math that's making my head hurt.
I guess I just need a bigger toy hauler
Old 05-28-2013, 11:41 AM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Now that's' a hauler
Old 05-28-2013, 06:06 PM
Rep:68
The more I look, the more I like the Silverback 35FL. I thought about getting a really large TT, but I'm sure I would regret it in the OK wind.
Old 05-28-2013, 06:53 PM
Rep:2964
2012 Ram 2500
ST
6.7L I6 CUMMINS® Turbo Diesel
crew | 6'4" | auto |4x4
3.73 axle ratio
Max Payload
2,425lbs
Max Tow
12,700lbs
CURB weight is 7200 pounds with 1 person weighing 150 pounds
GCVW is 20,000 pounds
http://www.ramtrucks.com/en/towing_guide/
if your Ram has a Manual transmission & a different Axle ratio
the weights will change a bit
you mentioned the GVWR
you should also check the GCWR
__________________________________________________ ____
Ram curb weight with 3 adults weighing 150 each 7,500 pounds
Unloaded Vehicle Weight 10,894 pounds
10,894
+7,500
18,394 pounds
that leaves you 1,606 pounds for your gear
If you get your water at the destination & dump it before leaving, that is quite bit of gear
