Help and information needed - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 05-25-2013, 12:18 PM
Floridagators1977 Floridagators1977 is offline
Vehicle: 08 Ram 1500 quad cab 4x4
Trim Level: NA
Floridagators1977 is on a distinguished road
Default Help and information needed
Hello,
I am new here. I just bought a 2008 ram 1500 big horn quad cab 4x4 5.7. When starting from areas stop going through first couple gears and driving at low rom there is some type of chatter coming from underneath somewhere. It only has 50k on it and is in immaculate condition. Just did a full service on it. Transmission filters and fluids, differential fluids, oil change etc.
Dealer said its excess noise when the MDS is on and only running on 4 cylinders. Is this true or does this sound right. It sounds like a dang ups truck from in the cab but you can't really hear it that bad on the outside. Should I be worked that it is something else or does this sound right that it is just the MDS?
Old 05-25-2013, 12:50 PM
Raminator5280's Avatar
Raminator5280 Raminator5280 is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT Bighorn
Rep:56
Raminator5280 will become famous soon enough
Does it have an aftermarket exhaust? Usually if it does it can make MDS sound pretty annoying. I bought a programmer and turned mine off so I don't have that drone when it kicks in
DiabloSport Trinity w/CMR tune, K&N FIPK, 87mm ported TB, Dynatech LT Headers, Magnaflow cats, ypipe, & muffler, Jetstream scoop, diy ram air, push start
Old 05-25-2013, 01:17 PM
Trim Level: NA
No aftermarket exhaust, yet. It almost sounds like valve chatter. That's just the kind of sound it is. I have noticed if I don't wait 15-30 seconds when I start the vehicle the torque converter doesn't fill back up and it shifts hard, but is I wait it shifts fine. I love the MDS, get great gas mileage
Old 05-25-2013, 01:22 PM
Rep:56
Depending on the muffler you choose you may grow to hate it with the aftermarket. As for the noise I am unsure. A lot of people talk about the "Hemi Tick" others have actually problems with lifters, ect. Maybe someone else will have a better idea of the noise
Old 05-25-2013, 02:03 PM
Trim Level: NA
Thanks. Another mechanic told me it was just excess chatter from the 4 working when the other 4 were shut off but I'm not sure. It does go away when more acceleration is applied.
Old 05-25-2013, 02:11 PM
Rep:56
Yeah that does sound like mds.
Old 05-25-2013, 09:37 PM
bparsel bparsel is offline
Vehicle: 2014 Ram
Rep:25
bparsel is on a distinguished road
Tough to say with those symptoms. The only time I ever notice the mds on mine is at stops. It idles rougher and has a vibration when the mds kicks in.
Old 05-28-2013, 07:25 PM
Trim Level: NA
I am more under the impression that it is the MDS now because whenever I turn of the overdrive it doesn't make that noise at all. And I have heard that with the overdrive off the MDS does not kick in.
Old 05-28-2013, 07:28 PM
Rep:56
Yes that is true. Same with tow/haul mode.
Old 05-29-2013, 02:52 PM
HemiLonestar's Avatar
Rep:300
HemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the rough
I am going to assume (which I usually don't) that since the dealer is doing it the correct weight oil is being used?
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red"
2006 Charger R/T "Little Red", 2005 Magnum R/T
(Mods list in profile)
2008 chatter noise mds, engine 5.7
