Keeping headlights on - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 05-25-2013, 01:46 PM
Munki63 Munki63 is offline
Vehicle: 2011 Ram
Munki63 is on a distinguished road
Default Keeping headlights on
Is there a way to keep your headlights on while signalling, Im about to install HID and I figure the on and off will shorten the life span of the HIDs
Old 05-25-2013, 02:11 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Install your HID lights with a wire harness and tap into the parking lights as a trigger, my 2012 does not turn off the headlight when a turn signal is turned on so I have no issues but this is what I would do if I had that problem, I also don't have Quads, I have duals, it might be different setup for DRL with Duals.
Old 05-25-2013, 02:16 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Are you installing HID's in your low beams or high beams/DRL? If you install them in your low beams they shouldn't turn off when you signal. It's only the DRL's that turn off when you signal during the day.
Old 05-25-2013, 08:47 PM
Vehicle: 2011 Ram
ive got HIDs for high, low and fog
Old 05-25-2013, 08:57 PM
Moderator
Rep:2140
Oh okay, the full shebang! Nice. Well from what I've heard your DRL's probably won't work anyway. The highs at half power isn't enough to turn them on.... I could be wrong though. Hopefully someone who has done the install chimes in for you.
Old 05-25-2013, 10:09 PM
Rep:3347
It would depend on what relay they used for the trigger if you're using a relay on the highs. The DRL output is 3.3V and most 12V coil relays pick up at 5V, so you may or may not be able to trigger the relay. If you don't run a relay harness then you're putting low voltage to the HIDs and they shouldn't trigger the ballast at all at that low voltage.
