Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 05-25-2013, 07:47 PM
pedroh6106's Avatar
pedroh6106 pedroh6106 is offline
Vehicle: 2005 Dodge Ram 1500
pedroh6106 is on a distinguished road
Default Replacing wheel hubs
2005 Ram 1500 slt quad cab 121000 miles; Squeal in front end, replaced pads but not rotors, next step is wheel hubs; my question is how do I know whether I have 2wheel or 4wheel abs or does it matter when ordering the hub assemblies? Thanks for the opportunity to post
Old 05-28-2013, 09:25 AM
bparsel bparsel is offline
Vehicle: 2014 Ram
Rep:15
bparsel is on a distinguished road
All you have to do is look at the hubs and see if the sensor line comes out of the top of the hub or not. The wire will follow the control arm up and then cross to the frame. My '07 has it on the drivers side and not the passengers side.
FYI - a hub/wheel bearing will typically emit a low growl when it is going bad, not a squeal. And that growling will change if you turn the wheels going down the road...you can also typically feel it in the floorboards if one is going out.
Old 05-28-2013, 11:38 AM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Agreed! A bearing is a roar, not a squeal. Most 2005 models come with ABS on the rears only. Check to make sure you don't have something lodged between your caliper and rotor.
Old 05-28-2013, 05:39 PM
pedroh6106's Avatar
Thanks for the info
Old 05-30-2013, 01:46 PM
SI Integra SI Integra is offline
Vehicle: 03 Ram
Trim Level: SLT Sport
SI Integra is on a distinguished road
Rogerramjet i right, check to be sure there is not something stuck in there. Sometimes the backing shield can rust out and debris can get stuck in there creating a horrible squeal. The other possibility is the rotor could be warped causing the pad to graze the rotor while spinning creating a whine. I have had that happen a few times.
Old 07-20-2013, 06:08 AM
csmothers csmothers is offline
Vehicle: 2005
csmothers is on a distinguished road
Not sure about your squeal. My experience with bad wheel bearings is a roar sound. That squeal may be the beginning of a roar. I believe most 05 models have rear abs only. There will be a wire harness on all 05 drivers side wheel hub assemblies. It is speed/ cruise control sensor. My cruise control went nuts going on and off, then quit and it turned out to be the wheel hub sensor. Good luck!
