Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 05-25-2013, 10:22 PM
tox's Avatar
tox tox is offline
Vehicle: 2000 Dodge Ram Sport
tox is on a distinguished road
Default Please tell me my intake is just REALLY dirty!
Is this what a bad plenum pan looks like? (Please say no, lol)
I have been replacing a lot of parts this last week: valve cover gaskets, plugs, wires, cap, rotor, coil. I thought the water pump seal was bad, but it turned out it's the timing chain cover gasket, so the chain is bad too, all new rad. hoses, thermostat, etc. I'm hoping I don't have to do the plenum too.
I'm starting to wonder if my truck was neglected.
2000 Dodge Ram 1500 Sport 360 quad cab loaded. Kegger mod: http://goo.gl/hXl48Z
Old 05-25-2013, 10:50 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
if you plan on keeping the truck you may want to replace it. you can permanently fix it for about $130 plus labor. it is almost impossible to tell if it is blown by looking down the throttle body. some of what you see is most likely a result of a pcv valve. you could install a water/oil separator on your pcv valve line to keep the oil from getting back into your intake from the pcv and it only cost about $40 max and you don't have to tear apart your engine. it should also save your catalytic converter a bit longer since you won't be burning oil that would normally be sucked in from the pcv valve.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 05-25-2013, 11:58 PM
tox's Avatar
tox tox is offline
I think I probably will be keeping it for at least a few years. My brother keeps telling me to get another GM, lol. Anyhow, it looks like I will be replacing the intake anyway because the thermostat bolt broke off in it, then the ez out broke off in the bolt, cobalt drill bits aren't wining in the battle with the hardened steel in the ez out, and I don't have a welder to put a nut on top.... what fun. The PCV valve was definitely bad, there was a good amount of sludge that looked almost like cake under the valve cover on the drivers side. So that got replaced.
Old 05-26-2013, 12:09 AM
from what i have seen watching other people on other forums i have pretty much learned never use a ez out extractor. the only way to tackle something like that is a left handed drill bit. if that don't work then you will most likely have to drill and tap it or use a heli coil.
i am guessing you used a cheap pcv valve from the parts store? from what i have read they don't work as good as the mopar ones. you may want to still consider putting a oil separator on the pcv valve line. most people are pretty surprised how much oil ends up in it in such a short time.
Old 05-26-2013, 12:55 AM
tox's Avatar
tox tox is offline
Haha, yeah I don't think I'll ever use an ez out again. I should've just spent the money and got LH bits and taps, would've saved me a lot of work in the long run.
I think I got a Dorman PCV valve, it was like $4. Could you direct me to a mopar one and the oil separator?
Thanks for all the help!!!
Old 05-26-2013, 04:38 PM
i think you can still get the mopar ones at a dodge dealer. i think they are about $10. the oil separator you can get at just about any parts store that has air tool. they are used to remove water/oil out of the air to make the tools last longer. you may have to glue the drain on it since they normally require pressure to keep them closed. this is not mine but what one looks like installed in a car.
Old 05-26-2013, 05:20 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Well, better late than never. The intake didn't look all that bad. I probably would have just gone and done it anyway since you've already done so much.
P.S. Tell your brother to mount a tow bar to the front of his GM (assuming HE has one) and you'll tow it around for him when it breaks down.
Old 05-26-2013, 07:44 PM
tox's Avatar
tox tox is offline
Haha, GM isn't that bad. I had a Sierra for almost a year and it was a solid truck even though it had been seriously neglected and needed a lot of major things fixed because of that. Not to start 'the debate' here, but GM doesn't have a lot of problems that Dodge has, lol, like the plenum and the trans for example. I just like the interior and exterior on Dodge more though.
Yeah, I think after I finish my current projects on the truck I'll have to install a separator!
Old 05-26-2013, 08:08 PM
i think i was told that certain gm products had the same plenum issue. every brand has good and bad things.
Old 05-26-2013, 08:28 PM
tox's Avatar
tox tox is offline
Yeah, everything has it's issues, that's true. Everything's fixable too.
I just stuck a magnet down the throttle body and it stuck.
I'm not sure if I'm going to get the Hues pan or this: http://www.ebay.com/itm/DODGE-JEEP-A...125f1e&vxp=mtr
It's probably easier just to buy the Hues one though.
