Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 05-27-2013, 01:20 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I wasn't talking smack about the GM's just a bit of good natured ribbing, looks like CW and the Pursuader have your issue covered. Good luck guys.
Old 05-27-2013, 02:26 PM
tox's Avatar
tox tox is offline
Vehicle: 2000 Dodge Ram Sport
tox is on a distinguished road
Ah, It's all good.
Thanks for all the help guys!
2000 Dodge Ram 1500 Sport 360 quad cab loaded. Kegger mod: http://goo.gl/hXl48Z
Old 05-30-2013, 12:57 AM
tox's Avatar
tox tox is offline
Do my marks look a little off or am I just seeing things?
How do I line them up together?
Old 05-30-2013, 08:41 AM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
got 2 options. 1 you stick the harmonic balancer back on so that you can rotate the crank or 2 remove the spark plugs so that the engine should turn freely.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 05-30-2013, 11:08 AM
Vehicle: 95
Rep:1776
OR you can turn the flywheel if the inspection cover is off, OR you can put the center bolt in the crank shaft and turn it with a wrench/socket. Just remember not to over-tighten it.
The easiest way would probably be to slide the harmonic balancer on enough to catch and it should turn easily enough by hand especially without the drag from the accessories usually attached to the front of the motor.
But I'm guessing you've already figured this out.
Old 06-01-2013, 12:54 AM
tox's Avatar
tox tox is offline
Thanks! I ended up just slipping the HB on and turning it, that was way easier than I thought it would be. The timing gears came off super easy, I was hoping I wouldn't have to go get a puller to get that off too. The new chain and gears are installed. Should I put some grease on it or just let it run dry until the oil gets to it? (same with the crank seal?) What kind of grease should I use if any?
Old 06-01-2013, 09:46 AM
Vehicle: 95
Rep:1776
For future reference...the bottom gear (crank). Just tap it with a chisel between the teeth on a 45 degree angle. Splits it in one shot and it falls off.
