Old 05-26-2013, 05:50 AM
astraintx astraintx is offline
Vehicle: 2013 Dodge Ram 1500
astraintx is on a distinguished road
Default True Dual?
Thinking of doing true dual flowmaster super 44s. Dont know much about exhaust but is there if any advantage to this rather than doing a si/do mufler? if so what set up should I do? pipe size? muffler? etc. Thanks!
Old 05-26-2013, 02:33 PM
........nobody knows?
Old 05-26-2013, 07:00 PM
Jason15004X4's Avatar
Jason15004X4 Jason15004X4 is offline
Vehicle: 2012 Ram 1500 4X4
Trim Level: st/tradesman
Jason15004X4 is on a distinguished road
On my truck I have the exhaust dumped behind the cab with straight pipe from the cat. Sounds awesome. Only a little drone around 1900 rpms.
Old 05-26-2013, 09:20 PM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
Are you wanting to do a di/do muffler? With no y pipe? Or wanting to run an x or h pipe? Or are you wanting to do pretty much 2 separate exhausts from each manifold?
You'll get the most out of having some sort of crossover some where in the exhaust. I'm not sure if there is any performance benefits to running and x or h pipe over a y pipe. I would suggest replacing the y pipe with a freer flowing one and doing a si/do muffler. That will probably be the cheapest way to go.
As for piping it will depend on the setup you go with. If you do a si/do muffler you'll probably want 3" piping before it and 2.5" after. But again, it all depends on how you set it up.
Supercharged, cammed, other things too!
Old 05-26-2013, 09:50 PM
I push the skinny pedal
Rep:3277
What you have for performance would determine the most effective way to run your system. For most vehicles with mild mods replacing the factory y-pipe or adding an x-pipe before a separated DI/DO muffler, you'll have the best performance. If you want true dual for the sake of having true duals, well, that's you choice. Going true duals should only really be done if you plan a very short exhaust track. If you do decide to dual it, then you would benefit the most from a cross-pipe between the sides to balance the exhaust pressures between the banks, even if you're not using it for the scavenging effect.
Kurtis
Old 05-27-2013, 05:16 AM
Rammona's Avatar
Rammona Rammona is offline
Vehicle: 2011 Ram 1500 crew
Color: PEARL HUNTER GREEN
Rammona is on a distinguished road
I agree with Cdnoilram, have a friend with a muffler shop, we got talking about a true dual system for Rammona, low and bhold a few hours and 1000 loonies later shes gotta louder smoother bark. 2-1/2" pipes off each cat, 2 independant flo-pro muffs(replaceing that trash can the factory put in.) but kick your tips out at between 30 to45 degrees in front of the rear pass tire. We stagered Rammona's, looks great.
one must though is that equalizer pipe, really makes a big differance.(DONT FORGET) Another must is to open fer lung capacity scince she'll be getting rid of the exaust so quickly you WILL need to add an intake. dont cheap out spend some money on a good one. do your research, find what works best for what you want her to do. Turns out way cheaper in the long run. Rammona is having a love affair with the injen tuned intake system. I recommend this from personal experiance . trc-control going off under accel. is tolerable when you factor in the gas milage without the lead shoes.
Old 05-27-2013, 12:58 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
if you true dual...cheapest crossover would be an H, which a muffler shop can make for you..this provides the best tq compared to an X...
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
