Old 05-26-2013, 01:20 PM
fbenkautz fbenkautz is offline
Vehicle: 2001 Dodge Ram Sport 4wd
Trim Level: Ram Sport package
fbenkautz is on a distinguished road
Default 2001 Dodge Ram Speedometer erratic, ABS and brake light on
I have a 2001 Dodge Ram Sport 4wd automatic with the 360 engine in it.
It has 106000 on the clock. The speedometer is all over the place, the ABS light is on, even though I don't have ABS, the brake light is on.
I have replaced the RWSS, the transmission sensor, cleaned battery cables and grounds, and have looked for loose wires. No luck.
I have run out of ideas. Briefly I got a po500 code after I put in new RWSS, but it doesn't repeat the code after resetting it.
Old 05-26-2013, 05:27 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Are you SURE you don't have rear axle mounted ABS sensor(s)?
Old 06-05-2013, 11:00 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
http://www.obd-codes.com/p0500
He has a 2001 1500
It will have rear wheel ABS at a minimum.
Additional question is whether he also has FRONT ABS. Take a look at the brake master cylinder and look for how many lines. Or look at a front wheel and see if there is an additional line to it (1 of them being from the brake fluid).
I wonder if you got the correct sensor for the rear differential.
Will you elaborate as to what triggered this altogether? What made you replace the tranny sensor? That one has a specific code for it.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 03-11-2014, 11:14 PM
Another brick Another brick is offline
Vehicle: 1998 Dodge Ram 2500 Diesel 4x4
Trim Level: Used
Color: Green
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Another brick is on a distinguished road
Had that prob. fixed with new VSS on rear end. also cured 4x4 which was nonfunc. $17 on line $27 @ Autozone (yes, they stock them!)
