Old 05-26-2013, 09:29 PM
Hydro's Avatar
Hydro Hydro is offline
Hydro is on a distinguished road
Default Remote Start
My remote has stopped working. Anyone have an idea what I can do to fix it?
Old 05-26-2013, 10:14 PM
thekid0311 thekid0311 is offline
Vehicle: 2005 Doge Ram Quad cab 4x4
Trim Level: Daytona
Rep:15
thekid0311 is on a distinguished road
is it factory or aftermarket? I would check fuses if you haven't already and then make sure you get a signal to make sure its not the remote.
Men will follow out of fear but will die over respect
Old 05-26-2013, 10:29 PM
Hydro's Avatar
I did check the fuses and they're all good. It's Factory OEM installed. I'm thinking it's the module on the hood latch as it reads as door open. I do not know how to check it. Any ideas?
Old 05-27-2013, 08:48 AM
Asur Asur is offline
Vehicle: .
Rep:4373
From what your saying it sound like the hood module, its probably just needs some cleaning or it could be the connection is corroded, find the unit under your hood, its either a push pin or a mercury switch like for the under hood light. check your connectors and see if they need cleaning, you can also take a test meter to it see if it is always staying open.
Old 05-27-2013, 09:41 AM
Hydro's Avatar
Thanks I'll check on the button today. The connections are fine, I removed them and they're not corroded.
