Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 05-27-2013, 11:21 AM
steveschaedel's Avatar
steveschaedel steveschaedel is offline
Vehicle: 2012 Power Wagon
Rep:61
steveschaedel will become famous soon enough
Default TPMS Problems
I had the opportunity to do some heavy 4wheeling this past weekend while camping - during this event the TPMS came on. It shows the front tires at 57 psi and the back at 58 psi. The yellow tire low indicator is also on. These pressure are a little low but I wouldn't think that is low enough to set off the indicator. What psi does enable the system ? How do I reset the system ?
Thanks !
Old 05-28-2013, 10:27 AM
pitch1 pitch1 is offline
pitch1 is on a distinguished road
I had a 2012 SLT and the TPMS drove me nuts. As little as 2 pounds difference would set it off. I traded for a 2013 Express and it is rock solid, and I kept the 17's that were on the 2012. Only difference I can think of is when they pulled the 20's off I think they re-aired the 17's with nitrogen. At least they put green caps on all the valve stems.
