Old 05-27-2013, 05:43 PM
Brandon .30-06 Brandon .30-06 is offline
Rep:29
Brandon .30-06 is on a distinguished road
Default Attention all 3.6l pentastar owners with higher than average coolant temps
Below is a TSB that mentions a water pump problem with your engines, I have seen many of you post regarding high temps and it may be related to this problem:
Water Pump
Part Numbers:
68079412A$
05184498A$
Issue Description:
Water Pump Noise and Elevated Operating Temp.
Chrysler is addressing an issue of NVH from the water pump on 2013 vehicles equipped with the 3.6 Pentastar. It has been described as a chirp, squeal, squeak at idle and operating temp. If the owner is bringing vehicle in for this condition, we would request the following:
Drain the coolant from the system and refill. Ensure to evac system properly. Do not flush with any chemicals. Retest vehicle. If the noise returns, replace the water pump. Otherwise drain and evac/fill is recommended.
If there are any questions regarding the request, please contact David Standley
Pentastar Current Quality cell (248) 462-9612. If you don't receive response within 15 minutes,please continue with normal repair procedure.
Old 05-27-2013, 06:28 PM
arietem's Avatar
arietem arietem is offline
Vehicle: 2013 Dodge Ram 1500 4x4 QCab
Trim Level: SLT - 8spd 3.55 20"
Color: Mineral Gray Metallic Clear
Rep:368
arietem is just really nicearietem is just really nicearietem is just really nicearietem is just really nice
Hi Brandon ... Reps to you .. do what is the process ? does Chrysler inform owners ? or is it up to the owner to just bring it in and schedule the work ?
Regards
Regards
Old 05-27-2013, 06:38 PM
Rep:29
Regards
no you must bring the truck in with a complaint, schedule the appointment and if the tech deems it being this problem, then the repair is done.
Old 05-27-2013, 07:44 PM
hattitude's Avatar
hattitude hattitude is offline
Vehicle: 2013 Ram 2500
Color: bright white
Rep:24
hattitude is on a distinguished road
Just curious.......
What is the normal temp for the 3.6L penstar..?
What is considered elevated operating temp?
Old 05-27-2013, 09:06 PM
fishin4ladyz fishin4ladyz is offline
Vehicle: 2013 RAM1500 QUAD 4x4 3.21rear
Trim Level: tradesman
Rep:14
fishin4ladyz is on a distinguished road
I had 230 degrees yesterday, hope the dealer doesnt tell me thats normal when I get new front struts put on this Wednesday due to the oil leaking out of the front left one.
Old 05-28-2013, 07:23 PM
Rep:14
Anybody take their truck in for this yet? What did the dealer say?
Old 05-28-2013, 11:16 PM
ramaries ramaries is offline
Vehicle: 2013 Ram
Trim Level: Outdoorsman
Color: Blue
Rep:39
ramaries is on a distinguished road
Can you tell us what RAM considers as "normal" operating temp range?
Old 05-29-2013, 05:03 PM
Rep:14
Sitting at the dealer. Told me "they run hot" but they will check it out next wed when they put in remote start.
Old 05-30-2013, 07:51 AM
arietem's Avatar
Rep:368
Ok, went for a drive, and my coolant temp was at 106C (222F) but the analog gauge is showing pretty much in the middle .. uummmmmm
Regards
Old 05-30-2013, 01:34 PM
Rexer's Avatar
Rexer Rexer is offline
Vehicle: Ram 1500
Rep:207
Rexer has a spectacular aura aboutRexer has a spectacular aura aboutRexer has a spectacular aura about
I tried looking in the owners manual but couldn't find the info...what is normal operating temp for the pentastar?
While on operating temps....what is the operating temp for the 8 speed supposed to be around???
